greyStrongWolf
 - San diego
Hi, can any one recomend a pair of lock on grips that will fit the varg? I dont have mine yet, but want to get parts ordered in before the bike arrives.
Thanks!
			Thanks!
as states above Compressed air works great if you have access. I would avoid anything that lubricates or leaves residue because nothing is worse than a new grip that spins.....or more dangerous than a new grip that slips off...Newbie question.
To remove the grip on the throttle side can I used wd40 or some other products without risking to mess up anything on the throttle unit?
Or shall I just cut off the grip?
ODI sells a grip that locks on the left side and slips over the throttle tube on the right side. So you don't have to buy two sets. Part # is H21UHWB for the black color. They also sell it in white, grey, and graphite. Rocky Mountain ATV sells them specifically for the Varg, RM part# is 2158110001 for black.Hi, can any one recomend a pair of lock on grips that will fit the varg? I dont have mine yet, but want to get parts ordered in before the bike arrives.
Thanks!
That's awesome news as I'm a big fan of the lock-on grips and was hoping somebody somebody would come out with a proper adapter. Have been using the ODI universal set so far with good results, but full lock-on is just the better option for me - ordered a conversion kit right away. I assume the magnet from the stock tube is reused?www.berm.co - Has ready converted throttles, or just the DIY kit to do yourselves!
What magnet?I assume the magnet from the stock tube is reused?
Well, the Hirschmann throttle uses a hall sensor so you have to have something that triggers the sensor to determine throttle position. That's a ring segment shaped magnetic (I assume) piece that sits on the cam where you usually have the end of the throttle cable attached.What magnet?
