greyStrongWolf
- San diego
Hi, can any one recomend a pair of lock on grips that will fit the varg? I dont have mine yet, but want to get parts ordered in before the bike arrives.
Thanks!
Thanks!
as states above Compressed air works great if you have access. I would avoid anything that lubricates or leaves residue because nothing is worse than a new grip that spins.....or more dangerous than a new grip that slips off...Newbie question.
To remove the grip on the throttle side can I used wd40 or some other products without risking to mess up anything on the throttle unit?
Or shall I just cut off the grip?
ODI sells a grip that locks on the left side and slips over the throttle tube on the right side. So you don't have to buy two sets. Part # is H21UHWB for the black color. They also sell it in white, grey, and graphite. Rocky Mountain ATV sells them specifically for the Varg, RM part# is 2158110001 for black.Hi, can any one recomend a pair of lock on grips that will fit the varg? I dont have mine yet, but want to get parts ordered in before the bike arrives.
Thanks!
That's awesome news as I'm a big fan of the lock-on grips and was hoping somebody somebody would come out with a proper adapter. Have been using the ODI universal set so far with good results, but full lock-on is just the better option for me - ordered a conversion kit right away. I assume the magnet from the stock tube is reused?www.berm.co - Has ready converted throttles, or just the DIY kit to do yourselves!
What magnet?I assume the magnet from the stock tube is reused?
Well, the Hirschmann throttle uses a hall sensor so you have to have something that triggers the sensor to determine throttle position. That's a ring segment shaped magnetic (I assume) piece that sits on the cam where you usually have the end of the throttle cable attached.What magnet?
This is correct, the magnet and the spring is reused.Well, the Hirschmann throttle uses a hall sensor so you have to have something that triggers the sensor to determine throttle position. That's a ring segment shaped magnetic (I assume) piece that sits on the cam where you usually have the end of the throttle cable attached.
I'm very interested in this.BTW, even with the stock throttle housing and spring you can adjust the spring for a lighter pull. It is a little difficult to explain, but there are two pockets in the cam where the spring tab can be seated. The first one is the stock and probably what you'd call correct one, but you can also use the following pocket which puts less preload on the spring and therefor also reduces throttle pull. Have been using this for many hours without issues now.
