Bonnell 40hp and 60hp dirt bikes and e-bikes
No the higher voltage up to some point is more killing. As soon as you get past a certain treshhold the amount of voltage hardly matters anymore until you get into arc flash territory.
You seem to miss the point of the human body being a resistor. The current a battery can deliver is not perse the current that will go through the system (in this case the human being shorted). Current can't go higher than Voltage / resistance and in the human case that resistance is quite a lott. I have no issue touching a 12V 400Ah battery for minutes. I do have an issue with touching a 400V 1Ah for more than 1s though.
400V/100.000 ohm (human body) is 0,004A, that would lead to death in just over a second.
I used your data sheet for that just for entertainment/education purposes, the real number is something different but you get the picture.
Another thing to consider with voltage: The higher the voltage, the wider of a gap it can jump. As voltage climbs, you need to start increasing separation between tracks on boards / etc to keep it from arcing out internally.
Think I got it now!
Between a 100 V and 400 V batteries, current that would go through dry skin would be around 1 mA and 4 mA, it does not seem that much of a difference but indeed, there is a regulatory safety threshold generally established at 120 V DC for ultra low voltage (under which no significant damage would occur for 3 s).
So that's another reason for some manufacturers to stay below 120 V.
After that, low voltage upper limit is 1500 V DC.
"Insulator" is a relative word, since, beyond a certain voltage, basically everything becomes a conductor, even air if the voltage exceeds 3kV/mm, and then you get an arc (like it could happen in an inverter with too close cables, for example) or a lightning in the sky. The same concept holds good for the skin.
For a 360 V Varg Alpha, the maximum current should be almost 200 A (just do 59 kW/360V) and at 90 V the same power will be achieved with a 4-fold higher current. AFAIK, both combinations would be deadly for a human body.
AC apparently is more dangerous and something to consider is that an AC voltage is stated as the RMS value, which is 1.4 times (more precisely, √2) smaller than the peak value: a 230V AC current actually has a voltage that keeps oscillating between -326 V and 326V.
Yes everything is a semi-conductor at some point. Some materials are just better at it than others.
I think they left themselves some room with a bit of a bait and switch with weight and price.
Since you pay more for a "race" battery which everyone will want to order and price and weight will go up.
Seems like it should be the other way around. It should come with a race battery, smaller capacity available if you want a couple to race.(hot swap)
The race battery should be the smaller one.
But for the same reason you're Stark isn't loosing 59kW at standstill and it not being on fire there won't be such a current through the human body. Even a lower one for 90V. The Stark is killing, but 90V would need very specific conditions to do so. Soaked, rubbed of skin etc.
If we are looking output Amps here and those are the killing ones. Why am i able to hold on to a 12V 400Ah for minutes without anything happening? ;)
No, but i'm afraid i'm misunderstood. Holding a low voltage - high amps battery doesn't do anything (living proof sits over here). Holding a high voltage will kill you.
I mean to say that the max output amps of a battery mean nothing when talking dangers to a human.
Battery's of low voltage tend to work for hours or even days under water.
The weight of one of their bike+battery packages is 98.3 kg (216.5 lbs), as seen @3:25 in the video that Beagle posted. It's probably the smaller bike with the smaller battery, but hey, other such bikes do not exist in the market!
I like this company. They quietly implemented pretty much all the ideas that we have talked about on this forum, perhaps minus the KYB suspension, which I hope could become an option. Who has one on pre-order? I will give Bonnell their own sub-forum when their customers come here.
Some testing going on in Florida, some sneak preview of the dashboard interface (and it's not a detachable smartphone) and removing the battery.
and... well if you're making an electric dirt bike, you just know Josh Hill must get some seat time really
The clutch is a tiny lever separate from the rear brake but they didn't get to test it.
It reminds me of an old school compression release lever and my hunch is it operates with similar effect. At least it doesn't seem like something you could easily feather/modulate like an ICE clutch.
Yes I can see it used for popping the front and free wheeling. One of the most common questions/objections about electric dirt bikes is about whisky throttle.
The Arctic Leopard i tested had the same thing. Didn't do hard Enduro on it, but i could see it's usefullness to avoid whiskey throttle. Although it sucks in clutch dropping since you don't have a flywheel to carry you up obstacles.
Oh I see. Most of the moto and HE riders I ride with use the clutch to modulate power.
True, i do on my 2 stroke as well. But that's less of an issue with the Stark for example.
But the most usefull thing, storing energy in the flywheel and letting that roll you over an obstacle with throttle closed, you don't get with an E clutch.
Ya it mostly strikes me that the addition of the clutch is mostly to satisfy habit and concern rather than function on E bikes. And I have to admit, I myself thought I was sacrificing something when I got my first E bike (which was a Stark) and didn't have a clutch. The first time I rode an E bike though I recognized that a clutch was mostly unnecessary in almost all key functions.
And back engineering a clutch or clutch behavior (beyond pure disengagement) into an E bike would not be trivial and largely duplicate what the motor is already capable of (for the most part) and it seems like Bonnell likely reached a similar conclusion. I do like the idea of having some kind of neutral or disengaged state but I kind of see that as somewhat distinct from clutching I guess.
Yeah the fully freerolling would be nice as well as the cutting power. For streetrides programming it as a engine brake would be great. Especially downhill somewhere in the mountains. Being able to frictionless brake on steep decents would be great.
For those purposes it would be enough to have a very small lever as an addition to the LHRB.
For downhills I assumed that using high regen would be ideal but without clutch you can't really modulate engine breaking/regen, is that what you're saying?
