- Netherlands
No the higher voltage up to some point is more killing. As soon as you get past a certain treshhold the amount of voltage hardly matters anymore until you get into arc flash territory.
You seem to miss the point of the human body being a resistor. The current a battery can deliver is not perse the current that will go through the system (in this case the human being shorted). Current can't go higher than Voltage / resistance and in the human case that resistance is quite a lott. I have no issue touching a 12V 400Ah battery for minutes. I do have an issue with touching a 400V 1Ah for more than 1s though.
400V/100.000 ohm (human body) is 0,004A, that would lead to death in just over a second.
I used your data sheet for that just for entertainment/education purposes, the real number is something different but you get the picture.
