7 Support Tickets in 4 Months — Now a Drivetrain Issue Stark Says is Tires. It Isn't.
Anyone else have a bad periodic vibration?
  • Total voters
    7
seedubb
Florida, US
Hey all. Long post incoming but I think it's worth the read — especially if you're an EX owner, considering buying one, or have dealt with Stark support on a drivetrain issue.
I love this bike. That's important context for everything that follows. The Varg EX is genuinely one of the most exciting things I've ridden and I want Stark to succeed. This post comes from that place, not from someone who wants to torch the brand.
The short version of my ownership history:
Four months in, seven support tickets. Check engine light on delivery from nearly no coolant. Arkenstone connectivity failure over Christmas that contributed to a small accident — I submitted 7 documented troubleshooting videos, YouTube analytics confirm 6 were never watched. Missing homologation kit hardware. Faulty chain adjuster. Screen protector shipped folded in half. Seat deformed under a cover at 70°F — warranty denied. And now an active, unresolved drivetrain issue that is the reason for this post.
Of those seven issues, Stark resolved two by shipping inexpensive replacement parts. Everything else was denied, unresolved, or fixed through my own research and effort.
The drivetrain issue — here's where I need your help:
I'm experiencing a rhythmic, periodic vibration with a fixed cycle of approximately 3 seconds at all speeds above 45 mph. Severity: just short of teeth-rattling on smooth tarmac. I also notice inconsistent power delivery at steady throttle — the bike perceptibly accelerates and decelerates with the throttle held constant. A second rider has independently confirmed both symptoms.
On performing a gear oil change I found:
  • Visible metallic buildup on the magnetic drain plug
  • Grey/metallic oil rather than clean fluid
  • No obvious gear tooth damage on visual inspection of the right engine cover
Here's what makes this more than a vibe:
I have a background in engineering and computer science. I wrote a Python optical flow analysis script and applied it to ride footage from a body-worn Insta360 GO 3S capturing movement of a bike-mounted Insta360 X5. The script measures frame-to-frame camera displacement as a proxy for chassis vibration.
Results across two clips:
  • 28-second sample: 8 vibration peaks, mean cycle interval 3.70 seconds
  • 38-minute extended ride: 198 vibration peaks, mean cycle interval 3.03 seconds
  • The cycle interval remains consistent regardless of speed, road surface, and throttle input
That last point is the critical one. Tyre-induced vibration is speed-dependent — the frequency changes with wheel rotation speed. This does not change with speed. A fixed 3-second cycle independent of road speed is not a tyre or suspension characteristic. It points to a rotating drivetrain component with a fixed internal period.
Video:
Stark's response:
Initial guidance was to bring the bike to a dealer — 155 miles away in Tallahassee. When I asked if Stark could pre-coordinate with the dealer before I committed to a 310-mile round trip, the recommendation reversed to "probably fine, just ride normally."
Most recently, after I shared the optical flow analysis, Stark attributed the vibration to knobby tyres on tarmac and stated the service would not be covered under warranty. This contradicts a previous written statement from Stark in a ticket that bearing damage found despite proper maintenance would be covered in full.
Tyres do not put metal in gear oil. A 3-second periodic vibration that doesn't change with speed is not a tyre characteristic. I've disputed this formally and requested a video call with their engineering team.
What I'm looking for:
  1. Has anyone else — particularly EX owners — experienced a similar periodic vibration or found metallic debris on the drain plug?
  2. Has anyone had success getting Stark to engage seriously on a drivetrain issue, and what worked?
  3. Any EX owners who have dealt with Florida Motorsports in Tallahassee for warranty work?
I'm not at the end of my rope yet but I'm getting close. The bike is extraordinary when it works. The support experience has been, as I described it to Stark directly, less "premium ownership journey" and more "self-guided adversity training."
Happy to share the Python script and analysis methodology with anyone who wants it.
— C.W.
Double post, but probably better in this topic:
As for the vibration. I've had simular effect of that from rimlocks on multiple bikes. Wheels that are very off balance can have weird effects that don't seem to correspond with wheel speed. On my Beta 250 it was the worst and from memory indeed around 3 or 4 seconds every shake.
Might want to give balancing a shot. Isn't that expensive and makes running it on the street a better allround experience. I do it with weights you screw to the spokes.
That doesn't explain metal in the fluid, but it doesn't have to be related
1.Has anyone else — particularly EX owners — experienced a similar periodic vibration or found metallic debris on the drain plug?
Yes and yes. After first oil change, the magnet had a substantial amount of metal particulate and the oil smelt "off". Flushed through, filled and change my oil every 5 hours (err on the side of caution). No particulate anymore.
As for the rhythmic vibration, for my bike it was either the chain (most likely) or the rear axle... both were far to tight from the factory. Once I reset the chain and torqued the axle correctly the issue went away. My theory is that the chain was putting the internals under tension and something was binding. Funny thing is it didn't feel speed dependant...
2.Has anyone had success getting Stark to engage seriously on a drivetrain issue, and what worked?
Yes, loads of people... their CS might be abysmal, but when you get to actual Tech support, they get things done.
Lost said exactly what I was going to say. I would definitely balance the tires - I always balance my dirt bike tires, because you can feel it even as low as 25mph and with wheel locks it can be really bad. I have also had a bad vibration caused by a loose axle and a tight chain, things to check. Personally, I would replace the chain if none of those things help, you might have a tight spot. It is a cheap and easy experiment. But I bet it is the tire balance.
In any case you still have nearly 2 years of warranty left.
So if it really is a problem, it will probably get worse, and eventually become undeniable...
So ride it like you stole it!
Agreed on the oil. The rear wheel that is scary. Maybe binding but a somewhat loose rear wheel (below torque value) itself could cause all sorts of undefined rolling behavior including and not limited to cyclic vibration. Not sure who was last touch on your bike, but bikes should not leave either the factory or dealerships like that it is dangerous.
At least in my experience nuts and bolts have tended to be over torqued when new but I won't rely on that again. Yikes.
One item in your review of the facts is off: If the vibration has a fixed period that is not related to road speed, it's not going to be any of the driveline spinning parts. Everything from the wheel back through to the motor have a fixed speed ratio relationship to road speed. The only motor not tied to road speed mechanically would be the coolant pump?
Might be a vibration through the whole chassis wich can come from the drivetrain or wheels though.
As in my example with the unbalaced wheels.
I've never had unbalanced wheels effects not be tied to road speed though. Below a certain speed, unnoticiable, in the problem zone you notice and there is a variation in period based on speed, and sometimes when you go faster than the problem zone they self cancel out, but speed was always a key factor in the impact.
True enough. But the often don't resemble every turn of the wheel. More a shake every 3 or 4 seconds. Between 40-80 that is often pretty consistent on my Beta's.
The vibration looks like every dirt bike I've ridden on the road to me. I always assumed the intermittent nature of it was from the different size wheels being out of balance/out of round oscilating against each other. The magnet on the plug is there to catch debris just like it did, I found some on my EX when I change the oil.
I would suggest trying some balanced street oriented tires, making sure your chain is properly adjusted and not unevenly worn.
