Bullionboy
- Leawood kansas
I’m wanting to convert a 450cc dirtbike to a street legal electric supermoto. what frame would be best and what’s the largest 96v battery i can fit? which qs138 is best suited?
thanks! i’d be riding street and stunt lots.. still uncertain if a yz85 would be better for stunting and wheelies. what range do you get@Bullionboy
I can only speak for CRF Frames
inside a Honda CRF 450 Frame you can maximum fit a Battery containing 286 Cells plus BMS etc. enclosed in a Metal Casing.
This will result in a 26S11P Battery 96v and 49,5AH (calculated with Molicel P45B cells) or 96V and 55AH (with Molicel P50B cells)
Thats the Max you get with a typical custom made amorge battery in a stainless steel case.
And it would be even swappable in a few min by taking off the Seat, Tank and the radiator shrouds.
these are the size specs of the battery:
Thats what it looks inside the Frame:
( if I where to order another Battery I would let Amorge make the Battery Cables come out of the front not the top of the battery as space is quiet narrow underneath tank and above battery)
above battery fits on top of a QS138 70H V3 Motor.
it will not fit on top of the 90H motor this sits way higher and gives then less space for battery.
If you are able to build the battery yourself sky is the limit xD and you can fill the whole frame up with cells but anything bigger than above means its a permanent fixed battery that you cannot pull out of the frame anymore without taking apart the whole bike.
Also to consider the Battery above has nearly the same weight as the combustion engine that I pulled out so the general weight balance etc stays close to what it was originally and what the bike was desinged for.
There are plug and play E-kits for recent model year Yamaha 450´s the Yamaha frame has also great space for batterys.
But yeah if you do it yourself you might be able to do it at half the cost of those kits. But this requires some commitment to research, learn, and DIY capabilities.
and would that setup be able to hit 80-90mph? i would ride highway every so often so worried about overheatingthank
What year CRF is that? And what did that Amorge battery run you if you don’t mind sharing?@Bullionboy
I have it in 22S13P and it cost me 2500$ to my door incl. shipping and PayPal fees.What year CRF is that? And what did that Amorge battery run you if you don’t mind sharing?
Not meaning to sound discouraging (on diy), but given your requirements you’ll need a lot of volts - so much so that Stark Varg likely a better route/fit…and would that setup be able to hit 80-90mph? i would ride highway every so often so worried about overheating
Most people go with the qs138 70h v3. Some people get the qs138 90h v3 because it has a bit more torque. It's a little harder to set up batteries with though due to the slightly larger size, as pretty much everything pre-made is made to fit with the 70h.which qs138 is best suited?
