questions about 96v 450
Some 450s have specific supermoto frames, for example TMs and old Italian Husqvarnas. TMs have been pretty successful in recent years in supermoto racing and usually those riders who use CRFs etc. for supermoto prefer the TMs when they try them.
Probably the engine played a role in the characteristics of those frames and I don't know how well an electric motor and a battery would fit. One thing to consider with TMs is that many of their 4 strokes have the fuel tank in the subframe under the seat and surely this affects the suitability for a conversion. Another thing to consider is that they use KYB AOSs for the forks and they make their own rear shocks; I've tried a 2021 300 enduro in an enduro track and their rear shock felt right to me.
Here you can have a look.
@Bullionboy
I can only speak for CRF Frames
inside a Honda CRF 450 Frame you can maximum fit a Battery containing 286 Cells plus BMS etc. enclosed in a Metal Casing.
This will result in a 26S11P Battery 96v and 49,5AH (calculated with Molicel P45B cells) or 96V and 55AH (with Molicel P50B cells)
Thats the Max you get with a typical custom made amorge battery in a stainless steel case.
And it would be even swappable in a few min by taking off the Seat, Tank and the radiator shrouds.
these are the size specs of the battery:
Thats what it looks inside the Frame:
( if I where to order another Battery I would let Amorge make the Battery Cables come out of the front not the top of the battery as space is quiet narrow underneath tank and above battery)
above battery fits on top of a QS138 70H V3 Motor.
it will not fit on top of the 90H motor this sits way higher and gives then less space for battery.
If you are able to build the battery yourself sky is the limit xD and you can fill the whole frame up with cells but anything bigger than above means its a permanent fixed battery that you cannot pull out of the frame anymore without taking apart the whole bike.
Also to consider the Battery above has nearly the same weight as the combustion engine that I pulled out so the general weight balance etc stays close to what it was originally and what the bike was desinged for.
There are plug and play E-kits for recent model year Yamaha 450´s the Yamaha frame has also great space for batterys.
But yeah if you do it yourself you might be able to do it at half the cost of those kits. But this requires some commitment to research, learn, and DIY capabilities.
thank
@Bullionboy
thanks! i’d be riding street and stunt lots.. still uncertain if a yz85 would be better for stunting and wheelies. what range do you get
@Bullionboy
What year CRF is that? And what did that Amorge battery run you if you don’t mind sharing?
I have a 96 volt x 45 amp/hr Amorge battery - I think it’s 26S x 10P with molicel P45 cells.
I think it would be perfect for stunting and wheelies.
At full power it can wheelie at almost any speed.
I’m getting between 24-28 mile range with aggresive riding with a combo of off road and street.
I had an Alta and I prefer this as it’s lighter with about the same range, just a bit less power.
FYI - it’s a 2005 RMZ250 with 2022 KXF suspension. I like the ride and it handles really nice.
Getting mine set up for street legal.
It’s a lot of fun.
which qs138 is best suited?
Most people go with the qs138 70h v3. Some people get the qs138 90h v3 because it has a bit more torque. It's a little harder to set up batteries with though due to the slightly larger size, as pretty much everything pre-made is made to fit with the 70h.
Personally, I'm going with the qs165 60h v3 for even more torque than the 138 90h, but it's even bigger than that motor, so I know I'll have a bit of a challenge on my hands with the battery, but I'm gonna be making my own, so I'm not worried. Just need to spend a lot of time planning it out.
No matter what you go with, 80-90mph is going to be extremely hard to achieve, the technology just isn't there yet. And if you do get there, it's likely gonna be from running tall enough gearing, which will considerably reduce your torque output, and will drain the battery a good amount faster. Most build only achieve 60-65mph, and most people only strive for that goal as well, because most know the difficulty and downsides to trying to get 70+.
