				While an automotive DC charger would be a natural choice, the connectors on those are pretty big already. So even if you figure out the CAN part, the adapter and cable would still be quite bulky as I don't think you could take a lot of short cuts with the voltage and amperage involved.If it's standard like NACS you could probably just wire up an adapter and charge from tesla chargers.
				 www.evengineeringonline.com
				The NACS is smaller than a gas pump nozzle.NACS is slightly larger than a normal gas pump nozzle. Maybe you mean CCS?
What is the North American Charging Standard (NACS)?
Learn about the components of the NACS charging system, including the role of the charging station and vehicle connector.www.evengineeringonline.com
Yes, unfortunately we don't have the NACS connector here in Europe - it is basically all CCS including the European Teslas.NACS is slightly larger than a normal gas pump nozzle. Maybe you mean CCS?
This picture looks familiarView attachment 13719
On the charger cable Pin A=CanL Pin B = CanH
