“Factory” bar mounts
Very nice work! If I might make a suggestion for a potential future revision, consider extending the front edge up past the back of the fender which will help with the mud accumulating between the battery and skid plate.
Thank you for sharing your work with the community.
photon
mass. us.
Beautiful work, high quality, id love if you can extend the skid plate to cover the linkage, ill buy it from you! keep up the good work!
Brillie35
Make Alta Great Again
Thanks,
didn't want to completely block the airflow around the battery.
As the autumn starts over here it gets pretty muddy.
So we can put it to the test.
Brillie35
I got no problem hooking people up with skidplates or other parts.
But shipping from the Netherlands to America would probably be half of what a set costs.
And i don't know exactly what the forum's policy on selling stuff is.
I am not in it for a commercial point of view.
And fabrication could take a while, if i am busy with other projects for my company that have first priority.
So if you have connections locally, i think you are better off.
With the files i made available, any engineer could use it as a base point and make the desired adjustments.
