Advanced Modes: What Are You Cooking Up?
FreddyFugazi
BVT
For me, advanced modes is a game changer. I've only put 58 miles on my Varg EX so far but I am really liking what you can do here. I didn't even realize this feature was coming when I ordered it, and the idea of custom tuning the regen curve honestly never even crossed my mind until they released it. I feel like there are tons of possibilities and together we can find a perfect tune for every scenario! For every person.
I know I know, it sucks that advanced modes are locked behind a subscription. But we all get three months free so lets put that aside for this thread and focus on other pros and cons of advanced maps so we can try to make the best of them. If you want to share one of your modes make sure to post the power and regen curves along with a description of what your goals were and how its working. I'll go first:
Easy Enduro
The goal of this mode is to make the bike easy to ride in the first portion of the throttle but provide plenty of power to have fun in the later half. The regen curve follows the same pattern: more relaxed at lower speed and stronger and higher speed. I like a lot of regen personally but too much sets me off balance. I think some of this is a matter of needing practice and better throttle control so for now its on the low side. I plan to make a duplicate map that has different regen levels to practice and figure out a sweet spot.
I originally had slippery hill climbs in mind where tractions is more important than power, but after tinkering with it and riding OHV trails all day this is my default ride mode for now. It felt great on the OHV trails which have plenty of bumps, ruts and rocks, with some open stretches, but no big obstacles where the lack of initial power would matter. It will be great for the dual-sport riding I do as well which is of similar difficulty. Not so great for wheelies though.
I still haven't tried the three-month trial. Sadly, I've been injured more than half of the time since I got the bike, and it's not related to the bike.
The red curve is a representation of the standard 60hp mode ?
Yeah I assume the red line is what the power curve looks like at 60hp in basic mode. You can't go above the red line in advanced modes.
Shane Pinney made an interesting note in his video about the power modes. If you first set a HP/regen number on one of the 5 basic modes and save it, then go to the same advanced power mode and hit the "circle" icon in the upper right, it will set the curve according to what you just selected in the basic mode. You can then go from there and adjust it to your liking. Haven't tried it yet, but seems much more intuitive than always go down from the max setting (red curve).
If I could make a suggestion, if one of the moderators could make a thread for "basic maps". As I discovered, when you start your pro subscription, it will convert whatever your basic maps are to into the advance graphs, but I didn't know that and I only had 60 and 80hp maps loaded. You can't reset them once you subscribe. It would be great to have a resource for what the basic maps are when translated to advance maps, for those that haven't started their subscriptions yet.
You should be able to reset the advanced modes based on the the basic modes. @drehwurm68 explained how to do it the previous post. Its the third icon from the right in my screen shots. However this does not appear to be working for the regen curve at the moment.
Is the virtual flywheel available on the advanced mapping now? I don't want to try the subscription unless it is.
The reason I ask is Sam brought it up.
  1. “Log / Tech Map” (maximum stability, virtual flywheel)
  • Power: 25–35 hp max.
  • Traction / throttle: very soft initial response, smoother ramp (pull the low‑RPM points down in the power curve).
  • Virtual flywheel: increase it noticeably so RPM does not drop instantly when you roll off.
  • Regen curve:
    • Low RPM: high regen (70–90%) so when you are crawling on logs / downhills you get strong engine braking.
    • Mid RPM: medium regen (40–60%) so it does not grab too hard as speed builds.
    • High RPM: lower regen (20–30%) so the bike can still coast a bit when you are flowing.
I do not trust Sam. My subscription ended in October but at that time you could only adjust the regen and power curves. I haven't tinkered with it at all since then.
The 3-month free trial feels more like an extended test drive than true ownership. I'm experimenting wildly now, but the subscription wall might limit the long-term "community tuning" vision they're aiming for.
