If it was sourced overseas, a low cavity count, class 5 prototype mold (500-1000 parts) would be well under 10k. Could probably do the whole plastics set for 20k? Just a shot in the dark.
I wouldn't bother with the front number plate either. I've seen a bunch of different number plates used. Also, isn't the EXR headlight a stock mask?
Because I didn't know that... oops!Why do you want the front fender? Its from a Honda....
I would go with Honda because of the symmetry of the exhaust. The number plates seem to be a mirror image of each other.My recommendation is for you guys to develop a metal subframe and adapt plastics from another brand
It's my understanding that the plastic rear sub frame is load bearing, so that is still a big worry in my mind... might leave that off for round 1.
This seems like an ideal Plan B... or Plan A.5My recommendation is for you guys to develop a metal subframe and adapt plastics from another brand
Slightly off topic: The real question is what do we do in 3-5 years when the battery packs start shitting the bed? I imagine you could tear them down and just replace the 18650's with new ones, but I wonder if there is enough clearance for the extra 4mm diameter and 5mm length of a 21700.
Do we know where the old molds are physically located? If we could buy back molds, it would be pretty easy to get a local injection shop to run them. In terms of cost, I'm sure the molds were 100's of thousands of dollars, but maybe for pennies on the dollar we could make something happen. It all depends on who owns them.Believe me, we’ve been thinking hard about long term battery service. I think we will have options by the time it becomes a real problem IMO. Surprisingly enough it seems this stupid plastic is one of the harder obstacles to overcome right now. It’s ridiculous and sad that the molds are out there not being used but nobody is allowed to do anything with them. What a shame. So much effort put into this bikes design and it’s now locked up in IP ownership BS.
Italy you mean.I believe they are in France at Acerbis headquarters
You mean what will we do after having ridden the bikes for hundreds of hours exceeding the usual useful life of a dirtbike by far?The real question is what do we do in 3-5 years when the battery packs start shitting the bed?
T | Plastic For Sale, 2018 alta mxr | Accessories, Plastic, Lights, Bling | 1 | |
Replacement Plastic for Alta Redshift Models | Alta Redshift -- General | 22 | |
Replacing Alta plastic | Accessories, Plastic, Lights, Bling | 17 |
