Bonnell 40hp and 60hp dirt bikes and e-bikes
Not really. In Hard Enduro often freeroll is best and brake on the brakes. But in more street like scenario's or very long gravel ish it would be great to use the same lever as a regen brake lever. Since it's just wires 1 lever can do lots of stuff. And sure you know wheter your ride will be Hard Enduro (clutch) or street/easy gravel (brake).
Yeah I am well aware that's how you're supposed to do it. If you (I mean: me) would happen to mess up, no regen would not kill your momentum 🫣
Anyway that's one of the things I find really cool with electrics, the ability to adapt regen (engine breaking) to the terrain, weather, traction... or to your skill level 😁
You could maybe use regen in reverse after that mid-climb stall 😁
I have this index finger trigger throttle for regen set up on my conversion bike with an EBMX X9000 controller.
It’s great when street riding to use for braking. I don’t use it off road because it is more like an on / off switch and it’s hard modulate and to use going over whoops or cornering.
I tried using it as e-clutch (the EBMX software has a setting for this) - it really isn’t that useful.
So for street riding it works pretty good.
But the most usefull thing, storing energy in the flywheel and letting that roll you over an obstacle with throttle closed, you don't get with an E clutch.
Yes, you do, if this feature is programmed in. The thing is, those who have the ability to program such things lack the riding and the tuning skills, and those who do not lack the riding and the tuning skills are not programmers and do not work for OEMs.
No, but i'm afraid i'm misunderstood. Holding a low voltage - high amps battery doesn't do anything (living proof sits over here). Holding a high voltage will kill you.
I mean to say that the max output amps of a battery mean nothing when talking dangers to a human.
Battery's of low voltage tend to work for hours or even days under water.
"Volts jolt current kills" is the saying I've always had in my head in this regard. But its also the amount of energy (volts x current) and the current paths that determine what damage is done.
