Clickers front fork
Spam Assassin
Has anyone found manual clickers that replace the screwdriver type clickers?
I found myself in some 2 hour CrossCountry races that ended up needing way more or less compression damping than expected. Some are mostly sand/MX tracks wich need a lott of damping. Others have lots of ruts and logs. Not always clear in advance.
Having the option to click it at a flat peace of track is way better than going through the pits and loosing at least 2 minutes. Also i have the ability to stop a few seconds and do clicking on the low side of the fork to do rebound. Also looking for those.
They don't sell to Europe and no motion pro dealer sells them.
I did however see a Chrome 6 reverense on the website wich is not allowed to be sold in the EU.
Please avoid these… moister and water gets trapped and will cause a bigger issue later.
Just spend a little bit more and put Enzo clickers on.
Suspension is vital and should never cut corners. Spend more on quality suspension upgrades and you will be in better shape.
Spending is not really the issue, it's more finding parts available in Europe.
What will be the problem with water bering trapped under there? I don't see anything wrong perse as long as that screw is properly sealed.
