Bloak
- Ontario, Canada
Brass insert stripped when trying to remove the shrouds. Plan was to remove insert and replace with a crimp nut. After looking around, I found that I had some hex drive head nuts and decided to go that route instead.
The hex drive head nuts screw in clockwise, so if the bolt ever gets stuck again, everything should just spin out counterclockwise
Maybe others have a better idea on repair to the delta/bat wing brass inserts?
