Cyssko
earth
thanks Rashid ,
It looks like there was some sort of brownout or blackout to the ACM. Could potentially be that the ACM got reset due to insufficient voltage in the 9V.
Note: When you are waiting for "target" in mutitool, wait a few seconds post shut down, then turn on the bike. If it does not work, fully shut down the vehicle, the laptop (keep the MT dongle plugged into the laptop) and restart the laptop w/multitool and try again.
hey , thanks
so i was not on a low 9V cell , i tried new once and doesnt change anything , it was a very hot day that day and i was giving her lots of throttle so maybe it overheat i dont know
i did try both of the technics you tell me and it does not work unfortunately ,
i tried to upload an older version of firmware ,the blue light start flashing then everthing says ready to start but the acm is saying waiting for target
and after an hour or more with the bike plugged in the state never moved it was just blue light flashing i had to aboart it
Bob367g
California
With the latest release of the Alta Multitool by member 416c7461, I created a tutorial on installing and using the Alta Multitool software on your own computer.
========Want to donate/tip?========
I have put this all together for the community for free.
However, If these tutorials help and you would like to donate/tip towards my efforts, please consider Donating To My PayPal
========Required Hardware========
You'll need this cable from the store: Alta Data Port Cable
And you'll also need this CAN-USB adapter: ttps://canusb-shop.com/index.php?route=product/product&path=20&product_id=51
========How to Install Alta Multitool via Oracle VirtualBox Virtual Machine========
I have built a barebones virtual machine for everyone to use. This is the simplest method for getting Alta Multitool running on your device.
This prebuilt VM includes:
- Alta Multitool version 3.37.11.ET
- Shortcut for easy launching
- 3 firmware packages, the last released packages for MX/MXR, EX/EXR, and SM
- Instructions
1. Download and install Oracle VirtualBox: Oracle VM VirtualBox
2. Download the prebuilt Alta Multitool VirtualBox VM (5.61GB): Alta Multitool Virtual Machine
3. Extract the zip file to a directory of your choice.
4. In VirtualBox, go to File > Import Appliance.
5, Select the extracted Alta Multitool.ova and click next.
6. Now in Appliance settings, you may need to define a few settings like RAM size, number of CPU cores to use, and a "base folder" where the virtual storage will be saved.
7. Click Import.
8. In VirtualBox, click Start to start the VM.
Login credentials if you are ever prompted:
Username: alta
Password: redshift1
========How To Use the Alta Multitool Software========
Note: Disregard the whole section in this video about the json file and the alta directory. Follow the firmware loading instructions in the section below.
Watch at the highest quality.
========Connecting to the Bike========
Here is where the bike side plugs in. Remove the seat, then there's a little black plug that you just pull off to expose the female end on the bike.
15524264092265824630406400934863-jpg.2591
Here's my bike plugged in showing the Dashboard view:
15524258056581507153834646369166-jpg.2588
Here you can see the Battery module which displays voltages of each P group. Each of the 4 colors represents a single module. Each bar (21 per module) represents 6 18650 cells connected in parallel. (6 batteries per P group) * (21 P groups per module) * (4 modules) = 504 individual 18650 cells.
155242589293137890251919307159-jpg.2589
Here is the Raw Signal tab, showing each individual data point on the bike in real time. There are 453 data points .
15524259978133869201363142271602-jpg.2590
========How to Update Firmware Using Multitool========
The "Open" button inside the Loader tab is way easier (and actually more powerful) to use than the "Update Firmware" button in the Versions tab. When using the function inside the Loader tab, there's no need to mess with the JSON file, and no need to place files in a specific directory. You simply select the directory where the firmware file (.zip extension) is located (from the download). Furthermore, for advanced use cases, lets say you're replacing a display on the bike, you may only want to load the firmware for the display, instead of "reflashing" the whole bike again. To do this, first unzip the [firmwarename].zip file so that each of the individual .aebin files are extracted. Then, use the "Open" button within the Loader tab and select the specific .aebin file for the display.
Note: If "Waiting for Target" is displayed for more than about 10 seconds inside the progress bar for any component, simply turn the key off on the bike until the blinking blue light on top of the battery pack (look through left side shroud gills) stops blinking, and then turn the key back to On. The update process should start after that.
I also want to give a PSA:
If you intend to try to "mix and match" .aebin files from different firmware pack versions for whatever reason, do so at your own risk. In some cases this will work (a few of us have done this), however you may run into compatibility issues between the individual components.
Were can i buy all the stuff needed i have a code 103 that i think mite solve problem
slowjet
Ma
I ordered a dongle from Onelapper, it came pretty quickly. He is non respnosive on the forum and hasnt logged in in almost 2 years but the dongle showed up quickly after ordering. (On a side not, the dongle is literally a 2 wire connection and can likely be made for under $10.) I have several canbus adapters but unfortunately I am unable too connect to the bike with any of them. Not sure why. The link is broken in the original post, but it appears the adapter listed there is indeed available here -> CANUSB (USB to CAN converter)
