My first post, a trick for mounting the footpegs
Anders
Hello all,
I am Anders from Norway, an old, slow enduro rider (65 now). I just brought home my Varg EX from the dealer. Opted to mount it myself, as a way of getting to know my new bike.
I must say that following instructions on Youtube isn't my preferred way of doing things (books are), especially since I live in an area with less than optimal phone coverage, and my workshop is too far from my house to have wifi. Things takes time, but am really looking forward to getting the bike finished with studded tires, ready for racing the Varg in our Norwegian enduro races. The first winter race is in 4 weeks time.
When I got to mounting the footpegs, I ran into trouble. Entering the pin should be easy enough, it seems. But no way! The bushings had a small dimple inside, making it hard to push through, and seemingly impossible to get far enough in to reach the threads. I filed away the dimple, but it was still difficult to reach the threads while overcoming the spring pressure.
I ended up with going back to the house to turn a small extender in the lathe. Put that into the pin's end to guide the peg pin into opening on the front side of the bracket. Voila! problem solved. I guess Stark should have made the pins a couple of mm longer to make the process easier.
Hi Anders,
I know you don't like youtube but this vid is for the EX, he says the pegs are a pain and shows how to do it at 3:30. He does use a rod and hammer to tap it in.
Oh and BTW welcome aboard!!
Hello, that was also the part of assembly process that slowed me down the most. Ended up getting a hammer and tapping it, progressively harder, until it went in.
Would a little oil or grease have helped?
I don't think so. The problem it that you need to
  • Hold the footpeg against the spring force
  • Push in the pin and twist the pin so it can enter the threads.
  • All this while you look into the hole on the other end of the pin to see if the pin is central to / is entering the hole.
All this is solved with my little helper device. The extension of the pin enables you to push the pin though the hole before you start twisting it to enter the threads.
Not the best explanation, but the ones that has tried to mount the pegs will understand, I hope :)
I ran into the same issue. My solution was to take a strap, pop it over the spring, pull it away from the edge and wrap it around the peg. Worked great, was able to start the threads with my fingers, which is the proper way to start a bolt to avoid a cross thread.
