- Temecula, CA
Yes there are. A bolt on each side of the frame, KTM style.Wow. They really are beautiful motor bikes.
Congrats, bet it's a short list of those who have both an Alta & a Varg in the garage.
Are there no adjustable steering stops on it ?
I have to share this because im honestly quite bummed about this. My charger came with a L5-15 plug on it, which means ill only be able to slow charge on 120v at the moment. Stark said this was a mistake and will be sending me a replacement plug ASAP. They also said all US owners will have a 240V plug with their chargers, im suspecting a L14-30 twistlock like our Altas.
The better option is for the charger to come with 240V twistlock and use an adapter for 120V. 240V will be more commonly used at the track.I hope the 240V plug will just be an adaptor to the 120 plug for those that don't have easy access to 240V?
Posting a video about that in the next few days.Curious about weight difference between the Alta & Varg.
Terrific - thanks.Yes there are. A bolt on each side of the frame, KTM style.
wow. You are flat footing? I am on my tippy toes on my Alta. I am short though. My policy is not to touch the groud anyhow. No dabs if I can help it.Terrific - thanks.
How tall are you Bryan ?, bike in pic looks smallish with you on it, does it feel smaller, thinner, lower than your Alta ?
Maybe I can live with 260 lbs on single track the overall platform is that compact.
I'm 6'1 if im standing up as straight as possible. The Varg sits a touch higher than the MXR, but my wife at 5'5" is able to touch one foot on the ground on the Varg.Terrific - thanks.
For my alta, I made a 240v adapter. I just plug the adapter into the geni 240v outlet and it charges almost twice as fast. I wonder if you could do that here and that way you could charge at 240v or 120v.I have to share this because im honestly quite bummed about this. My charger came with a L5-15 plug on it, which means ill only be able to slow charge on 120v at the moment. Stark said this was a mistake and will be sending me a replacement plug ASAP. They also said all US owners will have a
HadesOmega's WR250E Trail Attack Bike Build | DIY e-Motorcycles | 6 | ||
Finally, an electric bike video worth watching! | Humor | 1 | ||
G | Bike won’t shift from neutral | Stark Varg -- General | 3 |
