spare throttle assembly
AltaWest
San Diego, CA
Hello there,
Alta owner here, and first time posting.
I am sitting on four extra throttles, and some other Alta parts. $100 for each throttle, from Alta with connector. PM for more info.
electriclife
netherlands
i have a throttle for you and many other parts to. We are racing with these bikes here in the Netherlands. So maybe i can help you out. Check us on ESP electric speed products and electriclifestore.nl
allesad
Union, KY 41091
No throttle available for the original 17MX model. Hopefully I can protect mine...
Trying to better understand the replacement throttle situation for a 17MX.
- Does the 17 MX take a different throttle, than the MXR, EXR, SM?
- Is so does anyone have the P/N or Inventory for a 17MX?
- What is the difference between;
A) 2102308-03 THROTTLE, HALL EFFECT, HIRSCHMANN, 65 DEG, CONNECTORIZED
and
B) 2103959-00 THROTTLE, HALL EFFECT, HIRSCHMANN, 65 DEG, CONNECTORIZED, SHORTENED
and
In an easy answer. Yes, its a bit confusing because some hardware changes and mechanical changes occurred in production (YAY)
There are three flavors of Alta throttle.
2100664-04 THROTTLE ASSEMBLY, OVERMOLDED - These are for early VIN Altas (MX specfically, VIN99 is the rough cut point) - Liquidator has them
2103959-00 THROTTLE, HALL EFFECT, HIRSCHMANN, 65 DEG, CONNECTORIZED, SHORTENED - These are for All bikes (MXR, EXR, MX and EX) after VIN99. The shortened piece makes it easier to install grips.
THROTTLE, HALL EFFECT, HIRSCHMANN, 65 DEG, CONNECTORIZED 2102308-03 - These are meant for SM, they have a slightly longer throttle tube, but can be modified to fit the Alta variants that do not use the -04)
