Jasperfield
- WNC
I find it the other wayRear wheels are 4.25", there's no reason for larger, it would only be heavier and a tight fit between the swing arms. Tires are Dunlop GPR 300s. Both sprockets are stock Stark with the rear being 47T. Plenty of torque and speed. The stock chain is used without modification.
If you have found a tire that works that great. Just saying it's not as easy to just get a narrower rim and expecting a narrower end result, so to say.Not likely. The Dunlop 300s fit very well with arguably more clearance and significantly less weight. But, you can use whatever you wish. The Stark has plenty of power for both.
Did you do any suspension modifications? What spring and damper settings? I found a Stark Varg supermoto build here where they did a bunch of fine suspension and geometry tuning but wondered to what degree those mods would even be noticeable for a layman.I built this up in August '24 and it's the most fun bike ever.
