Stark MX Supermoto & Warp9
FYR
Central Valley, CA
I ordered an SM wheelset last week. Pretty excited to get them! Are you running a 5" rear? Looks like you've got the GPR300's, what sprockets are you running?
Jasperfield
WNC
Rear wheels are 4.25", there's no reason for larger, it would only be heavier and a tight fit between the swing arms. Tires are Dunlop GPR 300s. Both sprockets are stock Stark with the rear being 47T. Plenty of torque and speed. The stock chain is used without modification.
Jasperfield
WNC
In about a week I plan to order a Varg EX. This one (shown above) will be for sale with its brand new, unused 18" MX tires & wheels. This one is only lightly used and has very low mileage / hours. I bought it new at end of August.
Jocke_D
Sweden
I find it the other way :)
Most tires that fit the 4.25 will get to wide even though the rim is narrower. A proper 160 on a 5" will have a better fit.
  • Like
Reactions: FYR
Jasperfield
WNC
Not likely. The Dunlop 300s fit very well with arguably more clearance and significantly less weight. But, you can use whatever you wish. The Stark has plenty of power for both.
Jocke_D
Sweden
If you have found a tire that works that great. Just saying it's not as easy to just get a narrower rim and expecting a narrower end result, so to say.
For my latest build on a CR500 I did that exact mistake and went with a 4.25 but it ended up being wider when the tire went on.
