Did you ever get the issue resolved?If you are experiencing the same throttle issue as I did, than replacing the throttle will not help unfortunately.
please read the following thread -
Bike is on, but throttle not responding
Perhaps someone encountered the problem I am dealing with with my EX: after a charge, the throttle stops working. sometimes it's working intermitently, and now not at all. re- flashed the bike's firmware couple of times, replaced throttle with a new one, went through the harness' connectors...electricdirtriders.com
So far the throtle only works once every time I turn the bike ON.Did you ever get the issue resolved?
It only happens when the battery is over 90% charged. So I don't fully charge it.Did you ever get the issue resolved?
The ELMOFO Hirschmann is not the correct throttle for the 2018 MXR. The MXR use a dual redundant version with 2 x Hall effect transistor circuits… also made by Hurshmann. It has a 6-pin JST connector (3-pins for each Hall effect circuit)I'm no expert on Alta issues, but if it's your throttle, I believe there were 3 different types of throttles put on the Altas over the years.
Liquid Performance on ebay has this model, note the connector style: Alta Motors THROTTLE ASSEMBLY, OVERMOLDED [2100664-04] | eBay. Liquid Performance has been very good to deal with for Alta parts for me and others here.
My 2018 MXR came with the Hirschmann Hall Effect 65 degree throttle, I've seen it sold at various places, a quick google search showed it available here in Australia. If this is the one you need, perhaps you can find it closer to home?
ELMOFO Hirschmann 65 Deg Hall Effect E-Throttle
And perhaps someone here can chime in on your issue and help troubleshoot further, good luck.
