tools or tips for gear removal
schwankl
utah
Going thru the process of replacing my bent output shaft ... I have the bolt & nut securing the gears off, but cannot get the gears off.
I tried some harbor freight gear pullers, but they cannot get under the gears.
Sounds like I need these tools:
7702418-00 - Sprocket gear removal tool $114.99
7702485-00 - Gear Extractor Pinion $65.99
7702498-00 - Output shaft extractor adapter $15.99
7702499-00 - Outer race roller bearing driver $78.99
ebay/liquid_performance does not have them ... Anybody know who may - For rent or purchase? Or an alternative way / tool?
Thanks,
mike
I’m sure if you just ride it around like that for a bit, they’ll come flying off and you’ll be all set!
I think @TCMB371 pulled those gears recently to replace some bearings, so maybe he has some advice.
I have ground down puller arm tabs to make fit under gears -
tricks on pulling gears -
with Puller installed and tightened -
warm up gear slightly with torch
Lightly wack puller bolt with steel hammer
Thanks @VINSANITY - I think I got all the parts, gaskets, 2 different sized o-rings. Bryan and Rashid have put a lot of detail in this thread: My Output Shaft Snapped. ... If anyone else has to do this procedure let me know because got 100s of extra o-rings, and extra gaskets to trace/create new ones.
