Duncan
- Newport, RI
If you dump your Stark Varg and tweak the front end it could be just the rubber handlebar mounts that need to be reset. Remove phone cradle (one very overly complicated fabrication if I must say) remove bar clamps and push out the rubber bushings, massage them, put back together and should now be true. Also check to see if phone cradle got tweaked. Mine did slightly. Check flatness on a flat surface such as glass or granite. I made a jig with bar stock bolted to the cradle to straighten it. File off the two nubs to check flatness, you will see what I mean. Also, I put a zip tie around the right side of cradle to prevent losing phone. BTW: no, I didn't crash, she fell off the slippery stand when washing her!
