XTRIG 22mm KTM Compatible?
Foss
Stark SME
Vestal, NY
Hey guys, as the title states, just seeing if the KTM XTRIG 22mm setup will work with the Varg? My only thing is the mounting points for the fenders.
I do not know about the bearings. But I know you'd have to shim the bottom fork leg clamps because KYB SSS fork legs are thinner than WP 48AER legs. I have done it before, you can order shim stock from McMaster.com. It's pink, IIRC 0.015" thick, but you should verify this yourself.
Varg118
Eagle, Idaho
FYI if you didn’t see yet, XTrig makes these for Stark now. I have a set waiting to install…
You have to run the FlexFix clamps to use the phone cradle on top. They don’t show or explain that, but that’s what I’ve come up with anyway. Obviously you can run without the phone as well.
