- Pennsylvania
I have the same problem. Downloading ride logs is PAINFULLY slow. It literally takes longer than the actual ride to download the data.
It can take several days for a complete download. It all depends on how long the bike has been operated since the previous download.What is your experience with the downloading time of the bike's data into the Alta Multitool Software? My download is running for 24 h already and data from about 9 h of riding only and 0.8 GB data have been transfered so far.
Does somebody know what is the size of the internal memory of the bike?
If memory serves, the system will loop once saturated.How long can these bikes go without a download? Will they brick if not done by a certain mileage/hours, or do they just loop and rewrite over the oldest data and keep going?
That's good to hear, as I probably won't ever get around to downloading the bike. If it can take up to 24 hours or more to download, I just don't think I can live without it that long...If memory serves, the system will loop once saturated.
I doubt it will. Plus you can run the bike without the pump in most cases anyway.I wonder if this can't cause damage of the coolant pump as it's continuously running as well. Any ideas?
What is the procedure for charging the battery while downloading data?I doubt it will. Plus you can run the bike without the pump in most cases anyway.
Also pay attention not to run out of juice while uploading data (the bike does not sleep in that mode).
We never encouraged people to disconnect the pump during charging and / or troubleshooting out of concern that they would forget to reconnect it.Any reason against unplugging the pump for a long data download?
FYI, once a log file is downloaded to your computer, Multitool will not attempt to download the same log again the next time. So there's no need to leave the bike downloading for days on end until it finishes downloading all files. Its ok to stop the download process to go ride the bike. The process will resume downloading the log files it hasn't already the next time you plug the bike in.
Quick tip. If you don't want log files to be recorded during your long charging events, just simply turn the key off after the charging process has initiated. I believe the logs are only being recorded when the key is on.
Correct.Just to get this clear, once charging has initiated, turning off the key wont stop the charging and wont do any harm to the battery?
So only switching the run-stop switch to stop will turn off the charging?
I am unable to find the .alta folder. I have searched for it and could not find it. Did I skip a step?
