Jayfox911
- San Diego, CA
Just finished following the instructions. everything worked as expected. Thanks for the information and videos.
@schwankl i have enabled the vt-x in the bios. The strange thing is that when testing with securAble is says that the processor doesn’t support hardware virtualization?
The text doesn’t show up but it’s there. It should be your admin/main user password you used when you created the vm.After typing this command it asks for a password?. I cant type anything, so what am i missing?
Thanks
Looks like you are missing a space after the rwx before the /Next issue is when trying to create the shortcut, i get this message when using the first command in the terminal: Missing operand after sudo chmod -R a+rwx/home/redshift/.alta
Anyone has a fix for that?.
Thanks
I finally got the mt to work, and now it has begun to upload data. Just how much data is there? The bike has been synchronizing most of the day, and it’s still going.
It says it has reached file 77/80.
I updated a friends MX that had a low beam fault. After the firmware flash the low beam fault went away.Don't worry about the low beam and aux flags on MX/MXR.
.Alta directory is probably hidden.
also after the firmware flash the motor sync has required.
SB Moto ABS wheelie bar install / test | Brakes | 6 | |
My MXR to EXR conversion / lighting install | Accessories, Plastic, Lights, Bling | 25 | |
Screen protection for SM and all other bikes. Easy install. | Alta Redshift -- General | 18 |
