- Lake Havasu City, AZ
Thank you! I'm running WP AER48 with a spring conversion. Sadly, the tech put a "stiffer for a gas bike" spring in which I believe is 1.00kg but the math from another thread suggests needing a 1.10kg so I'm going to swap that and the shock soon. Both my current setup and the stock 4cs are far too soft for even regular motocross, nevermind SX/ax style tracks. I was bottoming just about everywhere on these tracks lol. Had to deal with what I had but looking forward to getting this bike set correctly so I can stop worrying while jumping itHey JW884
Congrats on the win, your riding well mate! Are you still running the stock WP 4cs suspension and do you find it too soft for those supercross style jumps?
WHOOAAAA!!! I hope you are wrong about your current spring rate because that would be softer than the MX stock spring rate. The stock MX front springs are 0.52 kg/mm, so the two are 1.04 kg/mm.Sadly, the tech put a "stiffer for a gas bike" spring in which I believe is 1.00kg
Yep.but the math from another thread suggests needing a 1.10kg
