Magoo69
- Massachusetts
My motor or gearbox seems to be getting louder. I have +\- 30 hrs on my Varg. I’ve change the gear oil twice.
Any of you experienced this?
I emailed Stark, I’ll keep you updated on what they say.That was my impression during my last rides.
I'm not sure.
it’s only louder while riding under load…it’s not going to show up on the stand.Do you have a video about that to share? I tried listening to the noise of my Varg while spinning the rear wheel on the stand and it seems to me that most of the noise comes from the chain. Are you sure this is not your case? Is your chain tension correct?
MINE IS THE OPPOSITE, BEARING WHIRLING NOISE IS LOUD WHILE UNLOADED, QUIETER OR UNNOTICABLE WHEN LOADED.it’s only louder while riding under load…it’s not going to show up on the stand.
I REMOVED THE CHAIN, TOOK A VIDEO AND SENT IT TO STARK AND THEY SENT ME A NEW POWER UNIT. HAVENT SWAPPED IT OUT YET DUE TO LACK OF FREETIME.Ok, so I understand it would be better to listen to it but probably it would be little practical, so I guess we have to use a description.
Then, how would you describe the noise? Is it just the normal whirring noise but louder? Does it sound like bearings losing preload and shaking?
How many hours does your bike have? Have you noticed any other problems like play in the countershaft or debris in the old oil when changing it? Have you removed the oil filler cap and inspected the gears with a flashlight?I REMOVED THE CHAIN, TOOK A VIDEO AND SENT IT TO STARK AND THEY SENT ME A NEW POWER UNIT. HAVENT SWAPPED IT OUT YET DUE TO LACK OF FREETIME.
Sorry for the many questions but such a problem is serious.
How long did it take for you to receive your replace powertrain unit?i now Have under 20 hrs, it started making noise at 10. I havent noticed anything else. They sent me a new power unit i havent swapped it yet. The way i ride with over 35 hp and 50% regen you cant hear it. i hear it in 15% 0 regen , thats my "load in the truck setting. i did also do an oil change at the time of the noise deminished. I tried to load my video but was unable.
Thanks, yea I shared these photos and video so others can hear and see what to look for with a defective powertrain.Wow!
That sounds not good!
How is it possible that a simple bearing can make such a nois after such a short time?
Maybe mistakes in assembly process.......
Tension, not in the end position on shaft or......?
Let us know how easy or complicated a motor change can be!
Good luck!
My hunch is that your chain was too tight.
