- Canton, Ohio
Yes, I’m using a Brembo clutch master cylinder with a 9mm piston, as recommended by Alta riders elsewhere on this forum. Works GREAT!EDIT: This would work for a Brembo master cylinder. The Formula master cylinder needs a straight 8mm fitting.
A length of 1300 mm is correct.
