Varg - Gear Oil Change
Foss
Stark SME
Vestal, NY
Yea whatever Amazon sent you is the wrong replacement. Obviously the image from their page showing unavailable compared to what you received is significantly off.
If you are looking to avoid the shipping costs then yes you will have to send what stark is looking for. You should be good to go with the new design. Or I’ll just send you one of these lol.
As you can see from my picture, the head of the toyota plug is way to big to fit between the threaded hole and side cover (see my pic holding the hex head plug up to the varg). The treads look correct to me, it's the size of the hex head that's the problem.
If this is the one Amazon sent you, it has the wrong threads, it says:
  • Thread Size: M12 x 1.25
Reactions: LTJ
Foss
Stark SME
Vestal, NY
Correct, and to add, these after market parts are stainless steel so the threads are stronger than the housing of the powertrain. If you cross thread or over torque the aftermarket plug it will damage and compromise your thread pitch. At that point you will need a brand new powertrain lol. But don’t tell stark you used an after market plug, your existing one failed and as a result caused failure to the seal (if it leaks). If you stick to your story you may have a brand new gen2 motor.
I guess I'm paranoid SV will send me the old plug design. I'm hoping if they do warranty it, they would make sure I get the correct design. Maybe it just doesn't make a difference, but with my warranty request, I asked they please send me the updated plug. I rememer someone (maybe this thread) got the old dumb design when the purchased it through SV.
Hell yea, get it under warranty! $2.90 is great, but they will probably charge you $15 shipping if you order it outside of warranty
Clutch
Jupiter FL
Just did the first oil change at 7 hours. As soon as I felt the bolt shift once I stopped, grabbed some pliers and used the T30 with equal force on the pliers and it came out without further damaging the bolt.
Oil looked fairly clean but did have a lot of metal shavings/material. Very light riding on mx tracks, mostly rolling jumps.
rtf
Pittsburgh, PA
I haven’t got through all 10 pages yet but is any consensus on the best oil to use or where to buy? The only one I saw listed was the Motul brand. Any other recommendations?
Thanks for the reply. That definitely readily available. Was of thinking of this, does this meet Starks requirements for the EX?
I would imagine any SAE 75w90 would meet the requirements. There is no clutch or any slipping parts so as long as it meets the SAE you should be good.
Oh BTW as you can tell after draining it uses a very small amount of oil, so a bottle goes a long way. I usually flush a little clean oil through, probably wasteful but I am paranoid.:ricky:
Clutch
Jupiter FL
I used Valvoline full synthetic 75w-90 gear oil 1 Quart pouch and it was more than enough, flooded it clean and still had plenty
Vega
Colorado
Just did my first oil change at five hours on my EX. Fluid looked new/clear, but did have a burnt smell. Magnetic drain plug had noticeable black metal particles, but otherwise so far so good! All the oil related bolts were easy to get off with Torx bits.
Tal
It should be snug, there is no PSI forcing the oil out.
Skysmotor sells the following products online: Servo Motors, Planetary Gearboxes, Spindle Motors, and Stepper Motors, and you can purchase them online if needed.
I think the MXs had their drain bolts overtorqued at the factory. Stark changed the design and the bolts now come with a 13mm wrench head.
Hey rayivers, I see in your signature that you own an Alta: does it have any problems with moisture in the gearbox? Does it have a breather hose?
I'd like to know the answers for the same questions from someone who owns an E-XC Freeride or any other electric motorcycle with an oil lubricated gearbox...
The Talaria Komodo has a breather hose, shown here at 11:55:
And the part number STD-FI-0003 should be the valve to reduce the moisture passing through the breather hose of the Varg.
