EX Custom iOS/Android App
I agree with @brongle here.
Downloading data does require the bike to be in a certain mode. A human helping and describing the issue is a big plus as well.
We actually don't know their stance on these kind of apps. Only lead we have is the E clutch voiding the warranty, wich i think is understandable since it writes to the bike and is not tested by them.
It's just that nobody really wants to find out.
So far they have been good on me regarding warranty.
Lets also remember we are dealing with a very small very fast growing company here. From a couple of dozen to 400 employees in about 3 years doesn't give for the most experienced crew. I work in a factory as Proces Operator and our internal learning program takes about 4 years. Just to give you a sense of scale of schooling they have to get to their crew.
Not every negativity is born from evil or greed.
@Erwin P : what makes you think the e-clutch writes data to the bike? All solutions I saw so far seem to do something with the throttle input, but that wouldn't write anything? Did I miss something?
It's bypassing Stark VCU to write its own input using its own algorithm
"The power signal from the throttle and the clutch signal from the clutch lever run into the RARE control unit. There throttle and clutch are combined and, as one precise power signal, sent to the Varg."
"After the clutch is installed, all system cables and data are routed into the RARE Control Unit. Meaning both the CLUTCH SIGNAL from the clutch lever AND the POWER SIGNAL from the throttle now run into the CU."
"The Control Unit is the central interface of the RARE Clutch system.
Serving as the digital brain of the clutch our patent pending calculation algorithm processes throttle and clutch signals in real time. - delivering precise and consistent engagement."
i have a different understanding: It's doing something with the throttle signal, but then uses the same input to the VCU as the original throttle. Imho that is no bypassing, it is a modification of the input signal.
Well there's no direct connection between throttle and VCU anymore, it goes through clutch CU where it's modified (combined to clutch input with clutch algorithm) before going to VCU.
So now the information fed to the VCU is not purely throttle input as intended by Stark. So ok, not bypassing, it's modifying input before going to VCU, I guess that's what could void the warranty.
yes and I find it more than understandable: Imagine what a car manufacturer or any bike company would say if you plug something between their electronic and their electric throttle.
@Hinkelstein my description was poorly chosen, but what i meant was well written by you 2 now.
I guess the clutch unit could and should work without issue, but it could always contain a fault wich Stark won't be happy of in a warranty case. I don't like it, but i do understand/respect it.
Help me out here.
I understand bypassing would mean entirely replacing one step in the process (for instance if the signal never went to VCU), how would you call adding an extra step in the process (as is the case here), would that be piggybacking?
Help me out here.
A dutch guy, a french guy and a german are discussing about english phrases ;-) I'd say intercepting but maybe a native speaker could help us out?
Yea i'd say intercepting is more accurate than bypass or piggybacking, but its also modifying the signal before sending it further.
The clutch unit intercepts the throttle signal, combines it with the clutch input, and then sends a modified signal to the VCU.
Norway weights in 😁
Great to have so many nationalities around the table. Even if that does not really help understanding the peculiarities of the English language 😉
@Philip : I guess US is the largest contingent of forum members (english language and starting as a Alta forum), could you give us a top5 or top10 of countries of origin for forum members?
One would say little to go wrong there with the signal. However i still get they don't want foreign signals in their bike.
And a French guy speaking English and even discussing more complex English... Who would have thought this day would come :ROFLMAO:
And i still believe you bastards actually speak English but are just messing with us tourists 🤬
Désolé je ne parle pas anglais
Je comprends un peu Francais. Ich spreche ziemlich gut Deutsch. Jeg forstår litt norsk. But except from German (and Dutch offcourse) it's pretty much of to English ASAP.
But everyone speaks Moto, lets hope that launguage won't be forgotten when E takes over!
To get back ontopic @brongle . Could you place the tightening toques in the not connected to the bike part? That way i can always look it up and don't need to connect to the bike.
Yep! I want to move the recording page and I guess some other stuff like the manual out to the main screen, I'll take a look at doing that soon.
Norway weights in 😁
I'm been living in Norway for 12 years, but I'm originally from Australia so have some knowledge of the English language, as much as we Australians tend to butcher it.
Yes! Manual and torques without having to connect to the bike would be highly appreciated
Really a great app and a very good one for checking the battery status.
I am still missing a rpm display of the motor in the dashboard, or have I overlooked it so far?
Rpm would be a great help to better configure the advanced mapping to see exactly which rpm range you are in.
Also good to check exactly in which rpm range the EX is whining compared to the quieter MX.
What is the current software version, mine says 1.5.1 (111)
SVAG for the win (y) Broke my Arkenstone and ordered a new one right away. A week later and the status of the order was still "being prepared". I was lucky that I had set my charging preferences to 100% before the incident so I could have guessed that after charging the bike would be full - could have been otherwise as well, but no way to determine without the Arkenstone. Downloaded SVAG and my riding trip was saved - Brongle I owe you!
After wasting 300€ I'm pretty sure the Arkenstone, which is one of my biggest points of criticism on the Varg anyway, will not go on the bike anymore. So is there a way for SVAG to determine if the basic or advanced power modes are active? In that case I would cancel my subscription and see if without contact to the Arkenstone the Varg will reset power modes once the subscription expires. Background being that I haven't been able to find a basic power setting that will fit me as well as the advanced one I've come up with, but while I'd be willing to pay for the advanced feature once paying for it every month with the subscription is just ridiculous.
Here's something that you will like. ;)
[around 10 seconds mark]
I'm not noticing any difference between Standard Power Modes and my creative Advanced Power Modes.
So your plan is not to use any phone in the console?
Did it came out?
I have the Gen 1.0, but when riding Hard Enduro i lash 2 zipties around it. Not that i ever lost it, but i don't plan on doing so either!
