- Canton, Ohio
There is already 12v "available" for the docking station, the radiator fan, and the water pump.the dc-dc converter.
converting the batteryvoltage 400V to boardvoltage(s) 12V, 5V, whatever
Yep, it was on. Who knows, maybe they need a bigger deviation before activation of the fault selectors.Hmmm and you checked with the bike on? It's possible they don't do/mean anything yet and they just added them for testing with newer firmware.
I have mx with fw 1.2.8 work OKMy app on Android doesn't seem to connect to my MX 1.0 any more. Any suggestions?
What version are you running? I think I know what I broke but just wanna double check.My app on Android doesn't seem to connect to my MX 1.0 any more. Any suggestions?
Ah interesting, I guess we will see what it holds. Good to see the app still works and connects on that firmware version. Does he have a lot of ride-time on his MX?
Ah yea thats the one sorry, I should be more specific when talking about versions...Version? Of your app?
1.6.0
About 300 hoursКакая у тебя версия? Кажется, я знаю, что сломал, но хочу ещё раз проверить.
Интересно, думаю, посмотрим, что там. Радует, что приложение всё ещё работает и подключается на этой версии прошивки. Много ли у него времени катания на MX?
Does v1.6.1 (build #36 on android) fix connecting to your MX by chance? It should be available in closed testing.Version? Of your app?
1.6.0
The best starting point would be the svag-mini repository, that implements all of what you want above. Because I built that on the ESP32 BLE stack it doesn't contain any of the PIN generation code because I found that wasn't required.I'd like to create an app for my watch that would show the remaining battery, mode, and speed.
How difficult is it to get the data?
When do you plan to publish the code on GitHub?
