Looking for stock EX valving
I only got to check out the fork as I decided I like the WP stuff better in terms of working on it so I made the switch. So here is the stock setup of my EX delivered in April, medium suspension (I assume the valving is identical with each of the setups, but I don't know for sure).
(14) 30x.11 for example means 14 pieces of 24mm OD, thickness 0.11mm shims
Base valve ID 6mm:
(14) 30x.11
24x.11
30x.11
28x.11
26x.11
24x.11
22x.11
20x.11
18x.11
16x.11
14x.11
(5) 13x.30
Baseplate 20x1.60
(3) 11x.25
Reb float 0.25
Rebound ID 6mm:
(3) 20x.11
12x.11
18x.11
16x.11
14x.11
12x.11
11x.11
(2) 10x.25
(2) 16x.20
16x1.60
Midvalve comp 8mm ID:
(3) 20x.11
18x.11
16x.11
14x.11
12x.11
(5) 10x.30
14x.11
17x.11
(2) 20x.11 trampoline base shims
12x.10 trampoline depth limiter
13x.30 trampoline depth limiter
Base valve ID 6mm:
(14) 30x.11
24x.11
30x.11
28x.11
26x.11
24x.11
22x.11
20x.11
18x.11
16x.11
14x.11
(5) 13x.30
Baseplate 20x1.60
(3) 11x.25
Reb float 0.25
Rebound ID 6mm:
(3) 20x.11
12x.11
18x.11
16x.11
14x.11
12x.11
11x.11
(2) 10x.25
(2) 16x.20
16x1.60
(3) 20x.11
18x.11
16x.11
14x.11
12x.11
(5) 10x.30
14x.11
17x.11
Thank you!!
