Thanks I tryThe best starting point would be the svag-mini repository, that implements all of what you want above. Because I built that on the ESP32 BLE stack it doesn't contain any of the PIN generation code because I found that wasn't required.
I'd like to publish the app but I decided to wait as Stark did reach out a bit ago and confirmed they are working towards improving the security of the app/vcu connection. That's a great sign and I'm glad to see they care about this stuff, but I'd rather wait for those changes (which admittedly might be on the Stark timeline of taking quite a while...), since its not clear to me whether they will be changing the underlying PIN-generation. If they don't change that, I'd rather not have it published on GitHub so I'll have to sort something else out for open-source. If they do end up changing that, or perhaps improving things to the point where Svag can't function anymore, I'd happily push stuff for reference, although obviously its a lot less useful then.
What are those bar handguards?
I can't lie, her "security PIN" is the equivalent of 1234.Security is turned off with a scratch behind the ear!
My 50% of my "security":
R-Tech.What are those bar handguards?
My MX 1.0 phone is locked. Using a pin code now. Work just like the EX phone the way you describe except that it sometimes the screen does not wake up when turning on the bike. Have to take it out of the cradle wake it up and open the Varg app manually,Maybe the MX 1.0 phone does not, but the Arkenstone does and you can enable the desired mode (pin, pattern) in the securities menu. The dashboard will still come up without the locking feature, but for everything else including the Varg app home screen you'll need to unlock it. That's how I've setup mine.
Is that a Rhodesian Ridgeback? Beautiful dog!Security is turned off with a scratch behind the ear!
He is! Just over a year... and already 65kg. He's the biggest I've owned (he's number 4) and just collected our new 3 month bitch (our 5th).Is that a Rhodesian Ridgeback? Beautiful dog!
I noticed he was big.He is! Just over a year... and already 65kg. He's the biggest I've owned (he's number 4) and just collected our new 3 month bitch (our 5th).
