I ordered a blind bearing puller kit.
After taking the rocker arm bearings out, I can confirm that the rocker arm bores are smooth and there is no internal step. This matches the pics on Stark's parts page.
Theoretically the bearings could be pressed straight through... although my bearing press made up from an M12 bolt and suitably sized sockets could only shift the single bearing in the short bore for the shock, not the double bearings in the other two longer bores.
But even with the puller, I can't shift the bearings in the pull rod. The puller is just breaking the outer lips of the bearing races. I can't get at the inner lips as they butt up against a step in the bore. So that's a problem.
I've a friend with an EDM so I can get those bearings cut out, but fuck's sake, it shouldn't be this much drama to service the linkage. I know that having needle bearings pushed up against a step is a standard way to do it, but I thought Stark was about doing better than that.
