Service your linkage and swingarm bearings asap
Getting ready to pull my rocker off. The Stark video clearly shows the Ninja girl loosening the rocker shaft on the chain side 1st. Then she goes over to the footbrake side to turn the jam nut. Here you are saying it should be the reverse order. Who is right????
I finally got around to servicing my rocker arm bearings after 130 hours and plenty of deep water crossings, including salt water.
They were close to fine, which is pretty amazing given how I've been treating this bike.
The swingarm shaft bushing has some damage from the needle bearing. I can't work out if that's abrasion from dirt or brinelling or a bit of both. That seal had some wear too so may not be sealing well. So those parts will get replaced next time I open it up... probably in another 130 hours.
Oh wow! You put that back in?!? And are going to wait another 130 hours before replacing it?!?!? That is absolutely destroyed as is! That should be replaced asap. It WILL destroy the bearing [and itself even more] in very short time, even with fresh grease
I absolutely hate how she's using the torque wrench to loosen everything. Especially hearing it click well before it cracks the nuts loose.
Putting the rag in the chain to pull the wheel forward before torquing the axle nut is an awesome idea though, I've never heard of doing that, but it makes perfect sense.
I think that the reason for which they have put a reverse thread for the lock nut is that when you tighten the shaft from the chain side, this action will result in also tightening the lock nut on the footbrake side and vice versa when you loosen the shaft. Or at least, in this way it's not possible to loosen the lock nut by tightening the shaft or to tighten the lock nut while loosening the shaft.
I guess that you can start by loosening the locknut first and it should work, but I don't see why we shouldn't follow the order of the video instead.
My suggestion:
- start by loosening the shaft from the chain side like in the video
- remove the shaft and support the rocker arm with your hand or put something under the bike to catch it gently in case it falls
- loosen the reverse lock nut and at that point the rocker arm will surely fall
I recently pulled my swing arm and linkage. Most of the bearings did have sufficient grease and were in good condition. The one exception was the pull rod, the bearing and race which were kind of dry and there was a mild scuff on one part of the race. Everything seemed in ok condition so a regrease will probably be all for this season.
I am not sure why the pull rod components were kind of dry, it is worth noting that the pull rod is not a capped design. Rather the race runs the length with 2 small seals one on each end and may be more susceptible to water and dirt intrusion.
To remove the paired needle bearings in the rocket arm, can they be pressed through from one sidor do they need to be pulled out? Is there an internal ridge in the bore that they butt up against or is the bore smooth all the way through?
I ask as I'm trying to press them through with a bearing press bodged up from a bolt and bloody hell, I'm cranking on the damn things and they don't want to shift.
EDIT: Stark's Sam says there's an internal step, so I guess I need to get an threaded puller. One of the three bores has only one bearing and that one I've pressed out but the two bores with pairs of bearings, I can't press so I'm presuming that there's a step between the pairs of bearings.
That's unfortunate with my Yamaha yzs you could press them both out one after the other. There are some inexpensive puller kits available on Amazon if you don't have one. I have the Tusk kit that I got from Rocky Mountain. It is kind of cheap but does the trick for most basic cases, but I wouldn't consider it shop quality that for sure.
Can you please keep us posted on what you will actually see after having removed the bearings? I don't know whether you are servicing an MX 1.0, a 1.2 or an EX but in either case, the picture of the rocker arm that I see on the official site in the spare parts section shows three bores without any step.
