Ok, finally got my bearings sorted. The paired bearings in the rocker aim came out with a blind bearing puller with a slide hammer. They should push through as the bores are parallel, ie they don't have a shoulder in them. Still, I couldn't get the pair of them to move with my bearing press so ended up pulling one then pressing the other.
The bearings in the pull rod were more of a drama. They are up against a shoulder in the bore so you can't get at the back of them. They would not move - the bearing puller just broke the outer lips off the races.
I tried heat. Boiling water didn't help. I could have gone hotter but I didn't want to ruin the temper on the aluminium. I tried hammering from behind with a screwdriver/drift against the tiny part of the inner lip that stood proud. That just broke the inner lips.
So fuck it, I took the pull rod to a mate who has a spark erosion machine.
If you don't have a mate with one of these machines, then good luck.
I'm going to stand by my statement that the pull rod is a bad design. There's no reason to have bearings pushed up against a shoulder. Stark could have used a parallel bore with a floating bushing inside to locate the bearings. Or they could have a plain bore with a shoulder on the outside of the bearing, like the rocker arm. That would let you press the bearings in to a known position by using an oversized tool that pushed on the bearing then stopped at the shoulder. The current design can't be bored out as the middle of the tube has a reduced outside diameter (well, maybe it could be bored out but I don't know if that would leave it too thin and too weak).
So Stark, please fix this for version 2.0.
Also, why no grease nipples anywhere on this bike? Sealed bearings are never sealed. Water and dirt will always get in. We've known the cure for this for a hundred years - use grease nipples to add more clean grease. My lower steering bearing and linkage bearings have only lasted 200 hours. That's pretty poor for a machine that's going to get dirty.
