Solved GPS navigation disappearing when the Stark VARG dashboard takes over
Martti
Estonia
If you try to use GPS navigation apps on the Stark VARG, the map disappears as soon as the dashboard screen takes over. This makes it near impossible (or at least tedious) to use GPS navigation apps other than the Stark official PRO subscription that gives access to Trail, Navigation, Tracks.
After some success with workarounds like split screen (link) or disabling the Stark app foreground (link), which kind of work but are not very reliable, I stumbled upon something interesting. When you set Google Maps to navigate, it appears as a Picture-in-Picture window on top of the Stark dashboard. But as with the other workarounds it comes with some limitations:
  • It only works with turn-by-turn navigation. You can't just see a map or follow your own GPX trail
  • If you tap the Google Maps PiP window to full screen, you get stuck in Google Maps and lose access to the Stark dashboard until you turn off the bike or restart the phone.
As none of it was ideal, I ended up building a dedicated app optimized for Stark VARG leveraging Picture-in-Picture that runs the map with a GPS trail on top of the Stark VARG dashboard. You can load your GPS trail (GPX), run it as a tile on top of the Stark dashboard (or use a plain map without a route), navigate complicated sections with the full screen map, and toggle between them. Right now it uses Mapbox maps, which are the same as what Stark uses in their app.
I named it Head North GPS. There are more details on how it works here headnorthgps.com and it's also available on the Google Play Store (link).
All ideas and comments are welcome. If there is interest I'll keep building it.
I'll try recording a track tomorrow but for now when I load my gpx file(9mb 282 tracks) it's shown as such: I can load bigger files but with fewer tracks and it displays correctly. If you want take a look at the file and let me know what I might be able to do. Thanks. Link to GPX file
ah! I see whats happening. Right now I've been building it around one continuous track per gpx file (like the one you get from stark app history). Your gpx is a perfect example of the direction I've been thinking about - a “ski map” with multiple routes in one file. I'll build it out in the next few days. Great find!
PS! What do you use to create the gpx? Would be useful to see what kind of features or metadata might make sense to support beyond just colors and separate segments.
The file was recorded over years on a Trail Tech Voyager Pro. I edit with various programs that I have including Trail Tech's old Rideleader program. I use Caltopo to import and work with the files. Also, now I remember having the same issue when I imported files into the Stark app I guess because it is also Mapbox. Thanks for looking.
That's a great app thanks ! I would love to have Waze in picture too, did anyone tried that ?
Thanks! Waze doesn’t support Picture in Picture unfortunately. Google Maps is the only alternative I’ve found so far. To get Google Maps to trigger PiP you need to start navigation and then exit the app using the Android home button (the circle) before the Stark app takes over. I’ll post a proper guide a bit later.
How are you using Waze with the Stark? Turn-by-turn navigation or for the alerts?
I'm using Waze mainly for cops and radar/alerts, I can make it work by disabling bluetooth but I can't see the battery unfortunately..
Quick preview of the next update. Working on a “ski map” view for GPX files with multiple routes (color coded, intersections, points of interest). The example in the screenshot has 242 trails and seems to work well. I'll release it once I've done a few rides and made sure there are no obvious issues.
If there are ideas on how to make the app more useful, or large complicated GPX files, do share. You can also DM if you have some secret tracks you dont want to share publicly that have interesting metadata to visualize.
The “ski map” multi-route update is now live. If it hasn’t updated yet, get it from 👉 Play Store
I’ve done ~200km with it. Seeing all routes at once makes it much easier to avoid missed turns and pick lines, even on tracks you know.
Besides multi-route, the update adds basic waypoint support and a few fixes.
Let me know how it works for you, especially:
- loading different GPX files
- switching between routes
- anything odd or slow
PS! Handles huge GPX files (tested with 280+ routes / ~180k points). Thanks @Jgottsch for the file.
This app works great! version 5.65, what is waypoint support and switching between routes? Any progress on adding recorded track?
• waypoints / points of interest - new for people on public release who did not have them before the update (test version had them for ~2 weeks)
• switching between routes - with multi route gpx you no longer follow a single route (no single plan). depending on how the gpx is set up you can get identical looking intersections (no idea which one to take unless you stop and check) or dead ends (no connecting route)
I was asking as I am not sure track recording is the next essential. Stark app records a track and while it has occasional issues it kind of works. What I sometimes feel I am missing instead is "as the crow flies" navigation (pick a point on the map, get direction and distance to it).
Would like to get more insight from people with various use cases.
I would love the Stark app to move aside.
As in use a 1/4 of the screen just for battery % and speed. Although speed doesn't really matter since how stupidly unreliable it is, combined with how far off it is when you use gearing suited for street riding.
I would love just a battery percentage somewhere on screen and the rest google maps or some other app i choose (that incluides reliable speed anyway).
Nice work! Almost sold. @Martti Here is an important one: to be able to track your buddies out in the woods....
Find a way to add turn by turn to follow a google maps live location / whatsapp live location sharing
appreciate it! both are good ideas and I’ve spent some time thinking about
Buddies
Its fairly straightforward to build for Stark riders, but in real life groups are mixed across devices and platforms, which makes it complicated. How do you use it right now? Is it for keeping everyone on the map at all times or more for meeting points when someone gets lost or left behind?
Turn by Turn
Two reasons I havent done it. Turn by turn routing is expensive (would need to switch from one-off purchase to subscription) and it falls apart off road (no official roads). The next update I’m working on has "as the crow flys" navigation (creates a straight line to the point you mark on the map).
As you know I'm using your app and it is essential to me because it displays multiple tracks. Buddy tracking would be nice I suppose if it worked smilar to location sharing on google maps. I've been using Voyager Pro for over 10 years with buddy tracking which works fair but with a limited range (maybe a mile) and less if hills are between riders because it is radio based.
Buddies
Turn by Turn
I actually just meant the pack leader if you get lost.
Probably much more diffecult to track multiple gps coordinates at once.
Thanks! This is great feedback
The main reason I'm indecisive about buddies is that it will require backend server, user accounts, etc which means ongoing cost and a subscription model (something that I've been looking to avoid). Before going down that route I want to make sure it solves a burning problem, not just a nice to have.
@Jgottsch - you've been running Voyager Pro for a long time. Is the buddies feature something thats being used for most rides? What happened if part of the group didnt have a compatible device, did it kill the point of the feature?
@madkuku - are you using anything right now when you ride in a group? if having buddies on your Stark screen would come with 6.99 USD / month price tag would you go for it and convince the entire group to do the same or you would gravitate towards the free alternatives (whatsapp, google maps, find my, etc)?
3-4 out of 10 of my regular buddies have/had Voyager Pro so tracking only came in handy when we were waiting for one of them and could see where they were and if they were moving. So it only worked if they were in range. I don't miss the feature and could probably use google share location for an emergency if it works without a cell signal.
