CR-E “250” Project
Votol is a great controller, but there are some limitations. A lot of the displays do report errors, speed, gears, and current, on the One Line format, but on the Display page in the software there is more information. But the Display page is only on a PC. I agree with Vince on the 72V, not that I have a lot of experience with 96V. Votol doesn't have a 96V controller. A DKD 061 display is the best in a lot of ways , smaller and good visual.
Votol EM260S is a great choice, price and size, but they have come out with a EM200 and a Em350. I don't know anything about them but imagine they are larger. I don't think they are 96V either. Ans as I said I can give you a good tune to start with, and I can help you tweak that. Merry Christmas and we'll talk to you a little later.
So the project is ongoing.
Refreshed the look, the suspension, and a few other things. Swapped the controller from a bac8000 to a Votol em260s which @DonCox helped me get going.
I’m still waiting on my 72v65ah battery from amorge using 50xg cells. Along with am auxiliary battery which is 72v15ah also using 50xg cells and will mount in the air box. Plan is to set it up as a “reserve” battery and use only rode mode 1 limited to 100amp and use this as a get home/to the truck worst case deal.
But I have researched using a blender a little and pulling from both batteries at once…however this seems a little more sketch.
Been messing with tunes and for my cross country type riding 20-25kw is plenty of power, 250-325 ish line amps.
Now I’m new overall to this electric game; but what I’m missing is rolling power. Wheelie over an obstacle when I’m moving power. The abrupt starting power is awesome and top speed is perfectly fine. However it seems as rpm goes up torque really drops off which makes sense but seems to drop off really fast and I’m missing the lift over a mud hole or log power…or maybe I’m just missing a clutch lol.
Anyway here’s a few pics. Thanks for all the help so far.
More to come…much more.
Hey Struggle, What battery do you have in it right now? You are probably down on amps. You may be asking for 50% power, and you might get 200A, but if you ask for 75% power, you still can't get more than 200A, when you get a 400-500A battery, you will fell the snap. I would get your gearing down to 13x 51 and with 400A, I would put on the 520 chain and sprocket
Still an older 72v34ah using molicel 42s
You’re probably right, I’m chasing my tail right now with this battery. I can see voltage drop a lot under acceleration.
New battery should be here in a few weeks. It shipped right before the Chinese holiday.
I’ll just keep getting the bike dressed up and am indeed planning to get it swapped over to 520. Only place I’ve seen with front sprockets is electro & Co. crazy, I can buy 4 for my other bikes for the price of one of these
I like the idea of using both simuiltaneously because:
• splitting the cells into more than a battery increases the overall surface and as a consequence the cooling capability
• splitting the cells into more than a battery makes it easier to use as much space as possible in a motorcycle that was not designed to have such batteries
• it's easier to swap two smaller batteries than a big one in case you decide to go that way
Having one as an energy reserve only means to keep it charged 100% all the time without discharging it most of the times, which is harmful to the cells.
Yes but it’s not two batteries of the same size. Same voltage yes but very different AH
I do understand that they will discharge “evenly” if connected correctly but there’s still a bit of “danger” in running parallel
what is considered a too big V-drop?
One way to look at it is as the voltage drops the amperage goes up for the same power.
What is the current limit on your controller?
And then what is the voltage for that same power level at that amperage limit?
At full throttle your controller's trying to draw the max power to meet the load requested. As power comes out of the battery, the voltage sags and the current goes up proportionally.
So if your controller limit is 300 amps and it's drawing 20kw, voltage is 66v give or take. If the voltage dips below that the controller won't allow the current to increase above 300 amps to make up the difference. So the power goes down, ie watts.
I run most of my builds at 20S12P which is 72V nominal 84V peak When I am on the gas (asking for 400A) in Sport mode, you can see 5-7 V sag. Here is a picture of me on an uphill sandy track on the throttle, asking for 400A, the battery was at about 50% ( 72V), and I got 316A at 65V.
Sag is a collections of all the resistances in your system, wire, connections, wire length, controller, switches, and contactors, and connections inside the battery, and the cells in your battery
I’m seeing 10v or so and pulling less amps. But it’s because the overall size of the battery is small at only 34ah and the battery is 2-3 years old… molicel 42s which I assume are “tired”
Either way no worries…..new way larger battery with better cells on the way from amorge
Still waiting on my new bigger battery from Amorge…..but regardless loving the bike. 10 miles of trails yesterday, quick charge and then 6-8 laps on the mx track. Gonna be hard to convince me to get back on an ICE bike unless it’s for dual sport/adventure riding.
Little update. Been busy
2017 CRF250R chassis
Updated plastics/tank/seat
QS138
Votol EM260
72v 65ah amorge battery 50xg cells and 72v15ah auxiliary battery in air box same cells. Battery selector switch mounted on side cover along with charging ports.
72v-12v step down for lighting later maybe
18” rear wheel
Fresh Tusk tires will be mounted up this weekend. Rim locks on front and rear.
Re valved and sprung suspension
Left hand rear brake
Trail tech kickstand
520 chain setup to replace the 428 as soon as my front sprocket gets here from Amp SprocketAmp SprocketAmp Sprockets, but…..currently looking for a 25+ chassis to do another build on so this is for sale as is probably $6500 ishIMG_5502.jpegIMG_5503.jpegIMG_5504.jpegIMG_5505.jpegIMG_5506.jpeg
Did you go with a 10mm or 9mm piston? Have you been happy with it? Do you have a part number for it or model and year it came off of?
My son and I are build a 2005 CRF250R conversion and he really wants to go to a hand rear brake. I have been told to use a Stark master, a Formula 10mm master from SIP Scooters(no stock) and evraceworks.com also has a 10mm master for their budget moto brake upgrade for a Surron. Amazon also lists KTM masters but don't want to waste my money on garbage. I really appreciate any guidance with this. Thank you
Link for the amazon one:
It was on the roller when I bought it so I really don’t know exactly what it is. Just that it’s off a KTM. It works great. I can lock it up anytime easily and has great feel on the trail.
If it’s a clutch MC, make sure that you can use DOT brake fluid and that it’s not designed for mineral oil instead.
Very neat, cool looking bike BTW.
