- Connecticut
The kit was for KTM/Husaberg.
Thank you. I'm buying one. Today's ride reinforced I need a stabilizer and the front shocks built. There was no way I could keep up with @Duncan and his buddy Hugh.
@Trialsman I've read your posts with alot of interest. I do put dampers on all my bikes and a recent long enduro with the Alta just reinforced that. Would you be interested in doing the triple with Ohlins mounts & damper, new bar mount work and steering head bolt conversion at a comfortable number for yourself? Access to proper lathes etc sure looks like the way to go. I would gladly prepay for all M & L. PM me if you're interested.
Correct, if you buy the KTM spec Ohlins damper, it will work with the KTM clamp. Once you switch over you can sell the clamp, axle and hub on the Alta classifieds for as much or more than the conversion parts. I actually made a few $$ coverting mine.I have considered that since it's a RedShift EXR and I do ride it to work some and around town. I'd like using a street type tire to swap out with a knobbie. You're saying that the steering stem needs no mods to mount a Ohlins type stabilizer kit with a KTM clamp?
Roger that - to clarify further, the KTM clamp is the one that drops into the stem as a race replacement. The Tusk hub just needs to be laced into a new rim shod with whatever new tire to run.
Spacers etc all still work?
RM is ?
Did you keep track of part numbers you purchased?
Will need to get a rear setup too if I go this way, but it'll be a poor man's SM then !
Thanks for the help on this...
