- Lake Havasu City, AZ
The main reason a lot of us do 72V is because the convenience of the parts. More controller options in 72V, like Votol. They do not have a 96V EM260S. There are Aliexpress stores that sell them, but I emailed Harry at QSMotors.com and they say there are no 96V EM260S controllers. Batteries are more available, most motors can run 96V, but really a 96V rated controller has to be good to 120V approx. The important parts in the controller are the Capacitors and Mosfets. They are voltage rated.
But I started 48V and went 72V about 5 years ago. Almost all my stuff uses the same chargers. Even my MX500 is 72V. I am now building a street bike , a KTM Duke 790, and putting in a QS138 90H V3 motor with a FarDriver controller, ND961200, and of course a 96V (nominal) battery.
Higher voltage is better for many reasons, but higher voltages, like the Stark and KTM Freeride run 300+ Volts get to be dangerous!!!!
I prefer the Votol Controllers, because I can work with them, but you are limited to 72V nominal. I wanted to put the 96V Votol EM260S on the Duke, but I wanted a reliable controller. That is why I contacted QS Motors. The sites that sold the EM260S 96V model had vague info. They would not state the Max voltage, that should be over 110V. I must now learn the FarDriver software.
