Stark mobile charger is out !
its software bug, It is not possisble with single socket/single charger
3,3kW on 230V - real current 14,3A from socket - I put once 20A on shucko for experiments - I use high quality audio plug and 4mm wires - it works but socket and terminals was VERY VERY HOT
I cant imagine to put 25-28A on regular outlet
Looks like this is only Temu Heavy Duty Premium Fast Charging. :p
From 60% to 90% = 39 minutes
After 25-30 minutes and around 75% the "current charging power" on the phone started dropping bit by bit, and finished at 3.3kW.
Shuko wall plug temperature rose from 19° to 27°.
Charger temperature from 19° to 37°.
Battery: 19° to 26°.
ChatGPT calculation:
Not that I've ever opened them, but both the cable that connects the wall socket to the charger and the one that connects the charger to the bike have a sheath that must cover more than a wire,
For the AC side I just use an adapter (plug and socket) with short single wires without a common sheath. One side of the adapter goes into the wall socket the other connects to the charger plug. Then you measure the amperage on a single wire (phase or neutral).
also stark numbers doesnt add up
they claim 82min 0-80%
3,3kW with 82min = 4,51kWh
4,51kwh = 80% ---> 5,64kWh = 100% :O
Maybe they meant 20% to 80% which is a common recharge span for EV and the SOC span where fastest charging is possible with lowest battery degradation over time. And that is only 60% of 7.2kWh so close to your calculation. Odd they would use a "0% to anything" spec since discharging to 0% is a no-no. My guess is the wording was "to 80%" and the fine print, somewhere, said "starting from 20%" or something like that. Ha.
Well, if they want to test fast charging in the Norhtern emisphere, this is the best part of the year to be successful because in the extreme heat of summer presumably the current would be limited because of thermal limits and when it’s too cold charging shouldn’t be done.
I also guess that enduro would be more suited to fast charging since the power output is less than with motocross and so it’s less likely to have overheating.
from some facebook group(not official)
6,6kW external chargers for track fast charging
i see the number 7 on the side of that 6.6 chargers... maybe its a logo but for me it seems like a "7" (possibly the 7kw power) and below maybe it says "stark future" in small letters, i dont really know... it could be a third party brand, interesting...
szczur333
Poland
one more pic
shucko is up to 16A but usually safe longer operation is 13-14A
for longer period of time in EU we have BLUE (1phase) or RED (3phase) sockets - and there are two of each (small 16A) or little larger 32A
Bodo
Yellow is likely the DC connector for the bike.
Red is mains, but possibly only distribution to the chargers. ~9x 6.6kW is quite some power draw
Bodo
Interesting text from that fb post translated:
Stark tests fast chargers during this year's Gotland Grand National ⚡
Several of you may have seen that you have been given the "choice" to charge up to 6.6kW on your own bike.
This is a temporary software that has been rolled out that gives riders on Gotland the opportunity to fast charge during the race with dedicated chargers from Stark Future.
Stark is here with a pit-stop depot for all athletes at Stark 🔥
You will not get 6.6kW out of the original charger even if it says so on the display.
(red is my highlights)
So,
  • Stark Future rolled this feature out only for the Gotland Grand National?
  • the bikes are physically capable of accepting 6.6kW
  • the software is capable to adjust the range up to 6.6kW
When do we get an adapter cable to parallel two 3.3kW chargers for fast charging?
Today I finally got to measure the stock charger with an amperage clamp meter on the AC side. Bike (EX) was at 60% when I started charging with 1kW raising the power to 6.6kW in 0.5kW steps in the app. Amperage would top out at 15.6A at around 3.5kW and then stay CONSTANT even though the Varg app was showing kW numbers all the way up to 6.6kW. So I hope that finally puts the myth to rest that the stock charger can deliver more than the 3.3kW it is specified for!
is not important that the screen shows 6.6kw on the power setting, but if it says that below the SOC number, on the "current power" or something like that i think its a little concerning, that number should be legit and real if is really reading the power correctly
