Ride update with new products installed and suspension tuning.
New additions since the last ride:
- 18" rear with a broke in bib and 1/2 used Dunlop MX52
- 14 tooth counter, 52 rear by DDC
- RK chain
- BRP Hand Guard Mouns
- BRP Pro Line Chain Guide
- Cycra Pro Bend Handguards
- MotoMinded Speedo Relocator
- MotoMinded bracket to run KTM mask
- Double Take Trail Mirror
- Alta Skid Plate
- Longer front brake line to get the line in front of the headlight mask and speedo.
- I have been adjusting pressures spring pre-load, compression clicker on the front to get a really great stable trail suspension setting for my 175lb weight with gear. I will schedule a trail/work day with Enduro Spec to tune these in better.
I feel range was slightly better due to many reasons. - I am getting used to the bike so I am smoother, suspension is at a "good trail setting", taller gearing, bib and better rear traction.
Heading up trail in #1 again. I did not wish for more torque, just traction. There was a big section of flowy trail that I wished I was lower in the motor rpm.
Future additions:
Protection by Bullet Proof. Discs and suspension linkage.
Taller gearing. (yes, I said that
) I am going to try a taller gearing to see if I can get to more of a tractor feel.
I am going to plate this thing so I can try to ride from my shop. (another reason for taller gearing) With that I need to add horn, tail light with plate holder, rear brake pressure switch, our Ultimate LED kit, and borrow some DOT tires. *Turn signals not needed in CO
Thanks for reading!
