Arctic misting fan
Fog 25
Castaic ca
Try a Arctic fan out today when changing. Battery temp went from 109 to 83. Also did not get the Thermal Limiting code today which was a plus 👍
Will check it out more next time out.
Interesting- I normally place a fan connected to the generator in the direction of the bike but unless there is measurable benefit conveyed by Alta I probably won’t be anal about it 🤪
This is from Altas guide to thermal limiting:
External Cooling: Water, mist, and especially airflow over the battery case will dramatically improve cooling. With a strong fan the cooling time is reduced to ~1/2 hr, even less with a fan, mist, and evaporation on the case surface.
