- Netherlands
For me it's more to use another Android phone. Just in case of back-up so when on a multi day Enduro trip a very misfortunate placed rock wouldn't complicate the trip that much.
I haven't experimented with the MX series yet but from my understanding the 1.2.8 VCU firmware is the first version thats the same between MX/EX models. Stark did have something in the release notes mentioning they aren't using the new bluetooth interface for MX models, but I don't know if that means its not enabled/doesn't work yet, or whether this app would just work out of the box. I have made sure that the VIN detection supports both models so hopefully once the app is released someone with an MX bike can test things out.After you replied to me in ste Stark FB group i got curious and looked for some info, and here i am ahaha looking for the android app, if you want a gen 1 Varg tester (who knows if it works ahahah) i'm here
I just installed on my iphone and connected to my MX.Apple has approved the build I submitted and it's now available for public testing. If you'd like to test it out please join the Public Test Group which is managed via Apple's TestFlight system. Feel free to give feedback either here or via the built-in TestFlight feedback mechanism (taking a screenshot). I should have time later this week to begin working on getting the Android equivalent ready and approved for public testing.
When you open the app for the first time it should request that you enable bluetooth permissions (and enable bluetooth if its disabled). You should then see a list with (hopefully) your Stark. Hitting connect should prompt you to put in the PIN which will be provided on the connection screen (the app may connect before the pin is fully inserted, I honestly am not sure how this happens but it seems if you don't correctly put in the PIN future connections may not work). At this point the bike should fully connect and provide you with the main home screen.
Awesome! I'm glad to hear it works on the MX, I'm guessing that's only true for the latest 1.2.8 firmware but I imagine most people have updated by now. Apple provides no way to automatically provide a pin, it must be input by the user. If it fails to connect in the future you can go into the system bluetooth settings, find the VIN in the paired devices, and select "forget" on it. I guess there is either some bug with Stark's VCU or the pin honestly may be completely unused, I haven't actually tested without it.I just installed on my iphone and connected to my MX.
I was trying to figure out where to find the pin, and then the phone connected to the bike, and the screen advanced beyond and seems to be working.
However the statement quoted above has me slightly concerned about reconnecting, but I see the pin at the bottom of the main (?) screen.
Since you have captured it, can you also automatically fill in the pin and send it? Perhaps you already are doing that?
I have an iphone se2024, which has a smaller screen than most, so some text is falling off the screen or overwriting other text, I will send screenshots, do you want them here or send through testflight?
I have (a couple times) received warnings on the Varg phone, water pump error, one time, and I think something else another time, Does your app "listen" for these?
And I understand it may be difficult to achieve without a bike currently having errors!
I actually have 2 MX vargs, but one of them is at the dealer now getting a new battery.
I will be in touch, if there is anything I can do to help I'm willing and eager!
Thanks for your time and effort on this, I'm looking forward to using it.
The very first screen was truncated on the right, but as stated, the app moved on from there quickly.Awesome! I'm glad to hear it works on the MX, I'm guessing that's only true for the latest 1.2.8 firmware but I imagine most people have updated by now. Apple provides no way to automatically provide a pin, it must be input by the user. If it fails to connect in the future you can go into the system bluetooth settings, find the VIN in the paired devices, and select "forget" on it. I guess there is either some bug with Stark's VCU or the pin honestly may be completely unused, I haven't actually tested without it.
Screenshots in either place should be fine, I guess maybe testflight may provide some extra data which is useful but I've never used it before so I can't say for sure. I imagine there are a lot of issues with text fitting, I'll need to find a better way to test different device sizes as the iOS simulator doesn't support bluetooth.
The app does listen for all faults and will display a red warning indicator on the dashboard screen if one is hit, but your also correct in saying its sort of impossible to test. I will say the Stark app itself doesn't seem to display all faults, notably while the VCU has the concept of a motor overheating fault the Stark app never uses this field to display a warning, only for things like the water pump, isolation faults, and inverter/battery overheats. You can see the list of faults and whether they are triggered in the service -> status page.
Edit: I just saw your screenshots and wow that's so much worse than I thought it would be on small devices... I'll work on a fix for that ASAP![]()
Yea I'll go through the whole app and try to make it work better on a smaller screen. Do you have your text size turned up by any chance or is that just the default?The very first screen was truncated on the right, but as stated, the app moved on from there quickly.
Also, I forgot to mention I am surprised how quickly your app paired with my bike even though my bike was turned off (red blinking light) when I started your app.
I didn't think BT was active when the bike is off, but it obviously is.
Do you have any other apps on the app store?
I do have my text size turned up, and I just sent you a screenshot of that.Yea I'll go through the whole app and try to make it work better on a smaller screen. Do you have your text size turned up by any chance or is that just the default?
The Bluetooth performance of the VCU is actually very good, the Stark phone itself is the limiting factor having a super old Bluetooth chip plus the app being somewhat poorly designed. The entire VCU remains running and monitoring things while the bike is in the "off" mode (which is really just more of a standby I guess).
This is the first app I've built or released myself, however I do have a background in software and at past jobs I've worked with similarly designed mobile apps.
Ok perfect, that'll make it easier to test with. I'll try and make sure it retains support for text scaling while being a bit more... usable!I do have my text size turned up, and I just sent you a screenshot of that.
I am 65 years old, so very small print can be challenging![]()
And, with the text size turned way down, it looks like all screens are no longer truncated.Ok perfect, that'll make it easier to test with. I'll try and make sure it retains support for text scaling while being a bit more... usable!
I'm wondering about the stats.
As I understand it, the Varg phone has to be connected to the bike and have a gps signal to track your ride.
Otherwise, hours and miles are not counted.
Do you know if that is correct and then I assume your app won't count miles and hours, or it will perhaps have a separate hours/miles tally?
I assume that accuracy would be influenced by tire size and sprocket size combinations.Correct, the Stark phone only records rides and ride data when connected to the bike. On the EX the VCU has an internal odometer based off (I'm guessing) the motor encoder that is very accurate (it has no concept of hours however). This is the number I display in the UI everywhere. On the latest Stark app for the EX this is also the number they have started using everywhere (previously it was only shown on the dashboard display when the bike was in-gear) including the ride stats page. The only thing I don't know is if this number is accurate on the MX, does the one you see make sense or does it seem inaccurate?
That's a lot of airtime. for every 7 miles you've been in the air for a whole minute haha.I assume that accuracy would be influenced by tire size and sprocket size combinations.
I’m not sure what to make of the “odo” number of 131.
Here’s the stats from the Varg phone.
I recently bought this bike used, and I noticed the same, I guess the previous owner was an MXer.That's a lot of airtime. for every 7 miles you've been in the air for a whole minute haha.
