EDR1
- San Francisco
Would be nice to know the optimum static & rider sag for both forks and shock. Did not see it in the Alta user manual or in this forum.
Date | Post ID | Thread title | Replies | Forum | Thread starter |
Jun 9, 2022 | 31932 | Alta MX Cone Valve / Trax Suspension Swap | 30 | Suspension | #76 |
Jun 8, 2022 | 31929 | Alta MX Cone Valve / Trax Suspension Swap | 30 | Suspension | #76 |
Sep 5, 2020 | 24341 | Compression and Rebound | 6 | Suspension | Oded |
Mar 21, 2019 | 13235 | Want to setup the bike for my weight. | 7 | Suspension | Geci |
Jan 27, 2019 | 10921 | Can you adjust the steering head angle and offset | 31 | Suspension | VINSANITY |
Jan 26, 2019 | 10898 | Can you adjust the steering head angle and offset | 31 | Suspension | VINSANITY |
Jan 26, 2019 | 10895 | MXR Rear Shock v.1 vs. v.2 | 8 | Suspension | TCMB371 |
Jan 23, 2019 | 10794 | MXR Rear Shock v.1 vs. v.2 | 8 | Suspension | TCMB371 |
Jan 22, 2019 | 10788 | MXR Rear Shock v.1 vs. v.2 | 8 | Suspension | TCMB371 |
Oct 17, 2018 | 6458 | Rear spring | 16 | Suspension | Pavetim |
Oct 16, 2018 | 6422 | Rear spring | 16 | Suspension | Pavetim |
Jul 5, 2018 | 3013 | How often to check the WP AER48 fork air pressure? | 13 | Suspension | Philip |
Jul 4, 2018 | 3001 | How often to check the WP AER48 fork air pressure? | 13 | Suspension | Philip |
Jul 4, 2018 | 3000 | How often to check the WP AER48 fork air pressure? | 13 | Suspension | Philip |
May 8, 2018 | 1156 | Is the Redshift MX suspension worth re-valving? | 13 | Suspension | Josh402 |
Dec 28, 2017 | 13 | Re-springing a 2017 Alta Redshift MX (and then revalving too) | 44 | Suspension | Philip |
Thanks Phillip! I tried entering the keyword “sag” into the general (not advanced) search which didn’t produce a result. Advanced search works.This forum's software is amazing. You go to Seach - Advanced Search, and then search for "rear sag" in the Suspension sub-forum.
I like 90 mm.
Date Post ID Thread title Replies Forum Thread starter Jun 9, 2022 31932 Alta MX Cone Valve / Trax Suspension Swap 30 Suspension #76 Jun 8, 2022 31929 Alta MX Cone Valve / Trax Suspension Swap 30 Suspension #76 Sep 5, 2020 24341 Compression and Rebound 6 Suspension Oded Mar 21, 2019 13235 Want to setup the bike for my weight. 7 Suspension Geci Jan 27, 2019 10921 Can you adjust the steering head angle and offset 31 Suspension VINSANITY Jan 26, 2019 10898 Can you adjust the steering head angle and offset 31 Suspension VINSANITY Jan 26, 2019 10895 MXR Rear Shock v.1 vs. v.2 8 Suspension TCMB371 Jan 23, 2019 10794 MXR Rear Shock v.1 vs. v.2 8 Suspension TCMB371 Jan 22, 2019 10788 MXR Rear Shock v.1 vs. v.2 8 Suspension TCMB371 Oct 17, 2018 6458 Rear spring 16 Suspension Pavetim Oct 16, 2018 6422 Rear spring 16 Suspension Pavetim Jul 5, 2018 3013 How often to check the WP AER48 fork air pressure? 13 Suspension Philip Jul 4, 2018 3001 How often to check the WP AER48 fork air pressure? 13 Suspension Philip Jul 4, 2018 3000 How often to check the WP AER48 fork air pressure? 13 Suspension Philip May 8, 2018 1156 Is the Redshift MX suspension worth re-valving? 13 Suspension Josh402 Dec 28, 2017 13 Re-springing a 2017 Alta Redshift MX (and then revalving too) 44 Suspension Philip
The motion ratio? It is somewhere around 3, but it it changes throughout the stroke depending on the ride height and the linkage geometry.1/4" shorter spring...what is the ride height multiplier caused by the linkages?
any idea what sag settings I should aim for in the Motool?The motion ratio? It is somewhere around 3, but it it changes throughout the stroke depending on the ride height and the linkage geometry.
Per the user manual: (measuring from the button on axle top the rear tip of number plate) 534mm unloaded & 504mm static or 30 mm static sag. ( (Will throw all my gear on the bike and take the race sag and post that here.) Would you have a recommendation for using the Motool since it attaches to the axle center and not the button at the top of the swing arm? (since the axle is closer to the swing arm pivot point than the button, it seems that I can expect a different result)Try 90mm race sag, check if you have any static sag, and see how it feels at the track.
You might have to go to 105mm if you do not have any static sag.
Nice! Where did you attach the glue-on plastic hook? (was thinking of going straight up to the fender if I can compensate for the additional length somehow)I use a Motool too. The numbers that I reported are measured using the Motool.
A | Looking for used Alta motor | Alta Redshift -- Discussion | 3 | |
J | Looking at a $6k MX w/code35+36 | Should I Buy an Alta? | 7 | |
U | New member from the UK looking for help/advice please. | Should I Buy an Alta? | 3 |
