- Netherlands
Yes and no. The total amount of it is dictated by the motor. At what speed it happens is dictated by gearing.HP is also dictated by what the motor delivers. And by the gearing. HP is independent from the gearing of the motor.
For example an ICE with 6 gears and meets peak hp 6 times over the wheelspeed range. At say 15, 25, 45, 60, 80 and 90 km/h depending on the gear ratios per gear.
Same applies to different gearings (wich are actually just gears that you can't shift but have to swap sprockets for) on an E. The lower the gear the higher the horsepower at lower wheel speeds and the other way around.
