Your bike likely has a software update ready to install. Look in the pdf manual or a YouTube video how to install it.Mine has a solid purple/magenta light. I can’t get it to go away and can’t do anything with the bike. Any ideas?
The manual suggests holding both mode buttons in this condition simultaneously for 5 seconds (Though I have found it takes close to double that amount of time) for the update. The light will change color and then flash in several different colors indicating success...Mine has a solid purple/magenta light. I can’t get it to go away and can’t do anything with the bike. Any ideas?
HI, Stark support have got back to me, it is a different but known issue, with the solid magenta light nothing will respond with the charger connected or not, the bike is completely frozen in this state.Your bike likely has a software update ready to install. Look in the pdf manual or a YouTube video how to install it.
What was the issue?View attachment 11183Today while normal riding on a sand track..
No rocks, no crash, no jumps cased.
Link to attachment does not workView attachment 11183Today while normal riding on a sand track..
Other known issues:
The standard tubes are usless, change the straight away.
The oil drain bolt is a t27 head, the supplied t25 will strip the head and require drilling or vice grips to remove it. Buy a t27 torx bit before you undo it.
You certainly qualify for new pegs. I assume you had the original “breaky” ones.hmm my phone did not upload the images on my post.. so second try here
In february i asked support if there is an issue and if they will replace footpegs even if they have not failed yet..
This was the Answer
I'm not sure what "negligence" is supposed to mean,,,
They said they are going to have it collected.Do you have to send back the old one?
