Stark mobile charger is out !
In the comments of their YouTube video "bending the rules" they have stated that it's compatible with the EX and MX models. Our @Erwin P has asked for confirmation about the compatibility with the MX 1.0 and I think that it is compatible since the part numbers for the chargers of the 1.0 and the 1.2 are the same.
In that video, when they show the adapter for charging stations, it seems to me that it just mates to a common Shucko plug and some people have already shown that this solution works with the standard charger that we have. I guess that we can buy that adapter from them and use it with our standard charger; of course I would want their approval to do so.
szczur333
Poland
type2 adapter to schuko isnt something new - you can buy one on aliexpress for about 15-20$
inside you have diode + 2-3 resistors and thats it, if you ride with friends you can always build custom adapter like TYPE2 to 3x or 6x schuko - with 22kW charging point you can charge 6 bikes simultaneously with full power
charger picture and specs from stark future instagram
Bodo
2.2kg is indeed very light for a 3.3kW charger. The Tiecheng used in the MX/EX stand weighs in at 6.4kg - just the bare unit without cables.
The portable charger also seems to have a small loop in the housing to attach a small cable lock to the bike. Convenient if you charge you bike during lunch out of sight in a public space.
This 3.3 kW charger looks way smaller than the 0.66 kW onboard charger that was intended for the 2025 Husqvarna Pioneer that may never see the light of day.
It should be easy to put onboard next models, may just need to provide access to some air.
