I initially tried the Rekluse package. It worked fairly well and kept the rear pedal. The lever is designed for mtn bikes and is a bit fragile. I wanted more power so I went with a brembo lever from a KTM clutch. Worked better but still not what I expected. Added a high leverage lever. Again, marginal improvement. Finally, I added a two piston brembo rear caliper from an older KTM 690 (I think) and got what I was looking for. Lever pressure/response similar to the front brake.
BTY, all the parts including the rear master bypass valve can be sourced individually. I had to fab a custom rear caliper bracket for the two pot caliper, however.
The LHRB is a real competitive advantage. More than offsets not having a clutch in my opinion.
